Asus F3SV motherboard
  • rigeback
    • Mar 2011
    • 420
    • Malta
    I was given this Asus laptop that was totally dead, so opened up to find a burnt chip, so decided to de solder it. Well as you'll see in the pictures the job didn't go too well as the chip disintegrated while I was removing the solder with the pump and then I noticed that the copper laminate had lifted so stopped since I do not have a replacement part anyway.
    Seeing the way things are I thought it would be best to get a second opinion before going any further because a new part is not going to be an easy placement with the board in this condition and will not even work.
    I downloaded the service manual to try and understand what this part does with its adjacent partner which I think is the same part on page 88 of the manual part number SI4431BDY? What I was hoping to soldered only 2 legs in position to revive the board, again there could be something else wrong that caused this part to blow the first place since the cooling system is full of muck and possible over heated the video chip!
    Any feedback would appreciated even if means junking the board in the end although it still not bad little machine if I can get to work again.
  • rigeback
    • Mar 2011
    • 420
    • Malta
    Re: Asus F3SV motherboard
    Right, with board viewer I was able to identify the part number and what its function is, I have attached the pdf incase anyone is interested. I suspect the diode between these 2 chips is also burnt so will replace.
    Next part is to solder Si4800BDY so as the D G & S Pins make contact with relevant lines
    • MaXwELL
      • Oct 2009
      • 14
      • Turkey
      Asus F3SV REV 2.3 BoardView necessary.Anyone in the archive?
      • glovecaps
        Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
        by glovecaps
        I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
        My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
        The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
        11-25-2024, 04:23 PM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • MakNCheese
        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
        by MakNCheese
        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
        Symptoms:
        • Severe lag across the system, including BIOS navigation.
        • Slow boot times and unresponsive performance in Windows.
        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
        • No error messages or BSODs, just extreme sluggishness.
        What I've Tried:
        • Replaced
        06-04-2025, 12:48 AM
