For the past few months, my computer has been very unstable, freezes, various BSODs all leading to a hardare problem, sudden black screens, all at random moments, and sometimes during Windows startup. These have worsened in the recent weeks. I've even had some corrupted psd files that I was working with recently (not at the moment of the crash, so that's weird).
I did not make any hardware change before it all started.
Here are the main components :
- Phenom II X4 965BE cooled by a Cooler Master Hyper 212 Evo
- Asus M4A89GTD PRO/USB3
- 2x2Gb Kingston HyperX 1600Mhz
- 2x4Gb Kingston HyperX 1600Mhz
- Samsung 850 Pro 128Gb
- WD Caviar Green 1Tb
I've tried :
- temperatures are all good according to HWMonitor and Speedfan.
- memtest86+ : no problem
- Prime95 for hours : no problem
- removing everything but the CPU, RAM and main hard drives, and outside the case
- using various video cards : GTX480 at first, then HD5970, then HD5850 and also the motherboard HD4290 chipset.
- swapping power supplies with a known good unit
- clearing all drivers and installing fresh ones
- I did upgrade the BIOS earlier this year but the latest version made the computer very unstable, so I switched back to the previous version and it worked perfectly until around August.
Sometimes the computer will freeze, and resetting it wont work properly : it will start but not boot, no beep, just a black screen and the fans spinning. It takes a few tries before it boots properly, or leaving it off for a few minutes.
Also, it happened several times that after a BSOD, Windows will BSOD again during the loading screen, sometimes three times in a row, and on the fourth try, start correctly.
The most common BSODs are 0x00000124, 0x0000003B and 0x00000050, but there were some other codes as well, and common descriptions are "PAGE_FAULT_IN_NONPAGED_AREA" or "MACHINE_CHECK_EXCEPTION".
So that leaves me to the only conclusion : the motherboard has an issue. It could be the CPU as well but it's quite rare these have problems.
I bought an upgrade kit (i7 4790K and Asus Maximus VII Ranger) because I need it for work, but it's still a pretty good system even after six years, so it's worth trying to repair it.
Where would you start looking ?
I've always taken great care of my computer, cleaning it regularly.
I've tried :
