Doesn't POST, spins fans normally. No image or beeps whatsoever. I tried to check some voltages and Vcore appears OK at 1.2V (measured at caps just left of the CPU) and Vram is as on the pic attached.
Would be great if I could repair it, though it hasn't some value, mostly as a learning experience. I have a similar MSI (low Vcore, will make thread on it), and I should get a nice i7 combo which I can keep if repairable
an destroy them. no matter how much I heat them, I can't remove positive pins from board. Any tips on that? I got Weller soldering iron, adjustable to 450 degrees C, and mechanical solder pump.
