ASUS ASUS P5VDC-MX Dead CPU?
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    Hi y'all,
    Good PSU/voltages
    CPU fan spins continuously - but no POST/Beeps
    Tried several good RAM in all slots
    Power LED on "system panel connector" does not light up - get 1.4V across terminals
    Green SB light is activated on Mobo
    Shuts down when holding in power button
    12V present on input caps, but no voltage on CPU caps (2 X 6.3v lytics and 5 X 4v smaller metallic "FL" caps)
    Removed CMOS battery and replaced.
    Also tried starting with no CMOS battery - But no change in situation
    If the CPU is faulty, does that mean that the VRM controller may not be activated?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: ASUS ASUS P5VDC-MX Dead CPU?
    Socket pins are the first thing to suspect on socket 775. Especially when it still powers up.
    If it powers up, then it's possible that it's just bent or a broken socket pin that's not shorting.
    (Only if the socket is fine, could RAM slots then be a possibility.)
    IOW, it's usually socket pins followed by RAM slots.
    Only if socket pins look fine would I then check the VRM circuit...
    But, I see that the motherboard in the photo has the heatsink on, thus the CPU got to be in there, too, so that makes the likelihood of a bad socket pin lower...
    It honestly looks like a bad socket pin, VRM problem or a broken trace to the CPU.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      • 31015
      can you burn your finger on the via chip or the small heatsink?
        • 31015
        some serious heat was here!
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 661
          • samsara
          All of the pins look good
          Replaced with known good CPU, but still no change
          The backside of board (that you circled green), and the the cap on the opposite side of the heatsink, shows no signs of heat damage.
          No, the VIA chip, or the north bridge HS, does not get hot
          After 5min:
          NB = 18 deg c
          SB = 20 deg c
          Ambient temp = 17.5 deg c
            • 31015
            what is the 3pin thing that got hot?
            maybe it's now dead.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 661
              • samsara
              What 3-pin thing are you referring to?
              Also, there is Power getting to the USB Ports (5.23V) as soon as the power button is pressed.
              Furthermore, the potential difference across the Power LED pins on the "system panel connector" is 1.44V - which is not enough voltage to light up the LED.
                • 31015
                3pin package in the circle, the heat that darkened the board came from it's legs!
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 661
                  • samsara
                  That's a vacant capacitor location.
                  Looking at the reverse side of the board, it doesn't look like there was any cap there to start of with - looks factory soldered
                  I did an image search for this board, and all the photos that i looked at showed the position to be unoccupied.
                    • 31015
                    not the missing cap, the fet/regulator just below it.
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 661
                      • samsara
                      Is that what happens when a mosfet fails - it seriously overheats?
                      Is the sink leg (as opposed to the gate) the one that would heat up like that, as there is no evidence of overheating anywhere else around the mosfet
                      And what would you do next?
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 661
                        • samsara
                        Here is the voltages across all the mosfet legs when it is turned on
                        I've labelled all the mosfets A to O on the photo
                        Letter Gate Drain Source
                        A 0 0 0
                        B 0 0 0
                        C 0 12.4 0
                        D 0 12.4 0
                        E 0 12.4 0
                        F 0 0 0
                        G 0 0 0
                        H 2.75 3.37 2.75
                        I 2.1 3.4 5.2
                        J 2.17 3.43 5.0
                        K 3.08 2.46 1.63
                        L 3.9 3.38 2.46
                        M 12.4 5.2 5.2
                        N 5.7 2.6 0
                        O (hidden behind RAM) 7.99 5.2 2.7
                          • 31015
                          still waiting for a part number.
                          • socketa
                            Asbelowsoabove
                            • Jun 2014
                            • 661
                            • samsara
                            The mosfet in the green circle is: Advanced Power Electronics Corp AP9T15GH
                            I get multimeter readings of:
                            1.53V G-S
                            2.12V D-S
                            • socketa
                              Asbelowsoabove
                              • Jun 2014
                              • 661
                              • samsara
                              Also noticed that the CMOS battery was dead.
                              Replacing it made no difference
                              Am only getting 0.17V across CMOS terminals
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Looks like either CPU is not being detected by the board or the board gets stuck before even POST begins. Or perhaps CPU VRM controller is dead or not getting a signal from the board to start running the CPU (but that would be a very rare case).
                                Try this: remove the RAM and see if the board beeps at you (usually two beeps).
                                Also, see how much resistance you get between Drain and Source on MOSFET H. Make sure to keep the multimeter on it for at least a few seconds (if there are any caps, they may need a moment to charge, and then your readings will settle more)
                                And just for your information:
                                C, D, and E are upper MOSFETs of CPU VRM
                                A, B, F, and G are lower MOSFETs of CPU VRM
                                MOSFET M is a pass-through MOSFET (when the PC is on), likely for RAM VRM supply
                                N is lower MOSFET of VRM for RAM Vdd (2.5 Volts for DDR, 1.8 Volts for DDR2)
                                O is upper MOSFET of VRM for RAM Vdd (2.5 Volts for DDR, 1.8 Volts for DDR2)
                                MOSFET L is likely for Northbridge<->RAM communication (2.5 V for DDR and 1.8V for DDR2... I think)
                                MOSFET K is either 1.5 Volts for the AGP connector or RAM Vtt and NB<->RAM communication (normally, that's should be about 1.3V, though, so probably AGP)
                                MOSFET J converts 5 VSB power into 3.3 V standby-power for the SouthBridge
                                MOSFET H... I have no clue! 2.75 Volts seems a bit too high for Northbridge Vcc (which tends to be 1.6 Volts or less for boards from that era). Yet, it is very close to the NB, which suggests NB Vcc supply. Or
                                The SOT-223 component labeled "I" on your diagram is perhaps for the clock generator - that "ICS" chip with crystal next to it. And possibly for the RealTec audio and LAN chips.
                                So overall, most of the voltages seem fine, except for CPU VRM, which is just not there.
                                I have an ASUS A8V-MX, which is the socket 939-equivalent of your board... more or less. At least it appears to have the same Via NB/SB combo and same AGP and PCI-1x slots. I'll try to pull it later this week and see if I get similar voltages to yours.
                                • socketa
                                  Asbelowsoabove
                                  • Jun 2014
                                  • 661
                                  • samsara
                                  Thanks for the additional info
                                  Removed RAM - No difference
                                  There is a RT9245A chip (Multi-Phase PWM Controller for CPU Core Power Supply) just under the Heatsink and after power button is pressed it has 5V on Vcc pin - So power is getting to the VRM controller
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Check pin 9 (PGOOD) to see if the controller is getting a Power Good signal.
                                    • socketa
                                      Asbelowsoabove
                                      • Jun 2014
                                      • 661
                                      • samsara
                                      I'm assuming that you mean pin 10 (not pin 9) of the RT9245A chip.
                                      Got no voltage on this pin after power button is pressed
                                      Also checked:
                                      Pin 27 (PWM1) = 0V
                                      Pin 26 (PWM2) = 0V
                                      Pin 25 (PWM3) = 0V
                                      Pin 24 (PWM4) = 5.2V
                                        • 31015
                                        i think those via chips should be running hotter - check they are getting power.
                                        i'm still thinking about that cooked fet.
                                        maybe it's blown or something it's powering is shorted.
                                        it really isnt normal to see that kind of heat mark.
