bad cap on 7600gt
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: bad cap on 7600gt
    if i spot Sacon FZ's on a gfx card, i replace _all of them_ ...
    no questions asked.. ALL of them..
    reason: if you ever had a (halfway decent and back then expensive) gfx card destroyed beyond repair (GF8600GT 512MB) by those sacon crapcaps, you'll always go like when you see them
    i even tend to recap a gfx card if it has sacons on it before even plugging it in for testing for the first time since the 8600GT desaster :O
    even Fuhjyyu's last longer than those sacons..
    (and fuhjyyus die rather slowly.. those sacons just blow up from one second to another... *crack*pop* .___. )
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Congrats on getting it going!
      I'd preemptively replace that 1000uF when it's convent.
      Yes, FZ are 'rubbish'.
      Rather nice word for them actually.
      Mann-Made Global Warming.
      - Dr Seuss
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        #43
        I'll try to remember that myself.. What's the best way to identify Sacon? the FZ written on top?
        -David VanHorn
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Yes.
          So I understand they come in 3 different can styles now but the FZ will be consistent.
          - Dr Seuss
          • olawlor
            • Mar 2009
            #45
            I've also got a 7600GT, and last night after a loud "snap!" I had four blown FZ69 1500 6.3V capacitors and a dead card. Reading this forum has tempted me to repair the card instead of just buying a new GeForce GTX!
            The stock capacitors at 10x12.5mm, with a 5mm lead spacing. FYI, 1500uF 6.3v electrolytics with exactly this rating are available from many vendors, including mouser, where six replacement capacitors cost under $2 total!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Yes,
              And not that you've learned an new trick you can keep your eyes open for dead video cards that come free and you can fix for $2.
              - Dr Seuss
              • Roger That
                • Jun 2009
                #47
                hey, guys!
                I'm recaping my whole egva 7600gt with the panasonic suggested above! But, since i don't know nothing about capacitores, i don't know which one should be replaced by the fz68 1000 16v...
                Any help?
                Just like above, please, post the link to buy from digikey, i'll buy all panasonics from there!
                thanks!
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  The 1000uF 16V are Ripple=1800 and ESR=0.022
                  You want the same or more for Ripple and the same or less for ESR.
                  Panasonic FC are not adequate.
                  If you source at Digikey and want Panasonic then you need the FM series but be aware you'll be replacing a 12.5mm long cap with one that's 20mm long.
                  Make sure that will work for you.
                  Specs wise KZE is almost an exact match for that FZ but it's still 20mm long.
                  - Dr Seuss
                  • Roger That
                    • Jun 2009
                    #49
                    Thanks for the quick reply!!!
                    Just like i said to you, i don't know nothing about capacitors...
                    So, i still don't know which one to buy.
                    There isn't a panasonic can replace that capacitor i specified ? So, where i can find some material to read about it ?
                    Thanks!!!
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Read hat I wrote again. - It's all there.
                      I even gave you the data sheets.
                      - Dr Seuss
                      • mzhang_2003@yahoo.com
                        • Sep 2010
                        #51
                        I can only find 1000uF 10V or 35V in RadioShack. I guess it's too risky to use 35V, but can I use the 10V in place of 16V? I see the ripple and ESR are close to the 16V. Thanks!
                        • MXM
                          • 430
                          • Unknown
                          #52
                          ^ dude is that ur real email? get ready for some spam!!! haha not from me thou :P
                          We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4951
                            • New Zealand
                            #53
                            I wouldn't want to plaster my email address all over the internet either...
                            Anyway... 35v would be a better choice, you should always choose a higher voltage rating rather than a lower one (remember, this is only the max voltage the capacitors can tolerate, not what they will supply)
                            Using a higher voltage rated capacitor will not blow your video card up or anything.
                            Definitely don't use a 10v capacitor, unless you know for certain the voltage will not be above 10 volts.
                            In any case, I doubt RadioShack sells any good LowESR capacitors anyway. Better off going with Digikey\Mouser etc
                            -David VanHorn
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Radioshack has NO low ESR caps. - NONE.
                              - Dr Seuss
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4951
                                • New Zealand
                                #55
                                Not even Samxon or something like Jaycar?
                                -David VanHorn
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Not here.
                                  All they have is Xicon 85C and an occasional not-low ESR Chemicon or Nichicon.
                                  - Dr Seuss
                                  • MatiasOC-S
                                    • Nov 2010
                                    #57
                                    Excellent data guys! now i know the caps i need! and FZ now is on my black list
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      these people sold me 85c gen-purpose xicons before i knew that i needed low esr.
                                      http://electronicplus.com/
                                      i recapped a modem adapter and a powmax with them. the modem adapter i installed at my moms workplace (still works), but i gave the powax to a friend a long while ago. i havent heard from him for a while and i lost his phone number so i cant tell him that psu is delivering out-of -spec voltages and ripple (then again he way not be using it anymore)...
                                      • cengique
                                        • Sep 2011
                                        • 6
                                        #59
                                        Thank you very much for the info. I just ordered some FZ68 1000V 6.3V replacement capacitors at Mouser. They had some from Nichion that fit the requirements you gave above and the specs listed in the Sacon datasheet you attached.
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • SluggerB
                                          Help identifying Aluminum Electrolytic SMD cap values
                                          by SluggerB
                                          I am trying to re-cap a Tivo unit, but am unfamiliar with how to decipher SMD Aluminium cap codes to capacitance and voltage values to swap them out. Here's what is on each cap...
                                          07-25-2023, 12:50 PM
                                          HP EliteDesk 705 G3 EliteDesk 705 PRO 1500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 705 G3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 705 G3 boardview and EliteDesk 705 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 02:15 PM
