BAD CAPS AND OVERHEATED MOSFETS at GA-VM900M
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    i have a GA-VM900M REV.2. bought from junkman..
    i am writing post from this board.
    there are 2 swallon and 1 broken off caps middle of the board.
    The back line of this area is red and fried.
    i changed these caps with Nichigan.
    and i realize that couple of mosfets is overheated these are near the bad caps.their name are 40TO3GH.
    i could not put my finger more than 3 seconds one, 5 seconds other.
    all of them swapped. overheat is disappear now.
    i can put my finger at least 15 seconds.
    pics will be add.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: BAD CAPS AND OVERHEATED MOSFETS at GA-VM900M
    Stop!!!!! Immediately stop using those replacement caps!! They are unreputable and can do more harm than good! Also, it is never a good idea to use any electronic device with bad caps. It can kill the board dead.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • Heihachi_73
      • 713
      Nichigan. Is that Rulycon's brother?
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        Wondering what's next. United Radio-con?
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • mikail13
          • Aug 2013
          • 93
          • Turkiye
          maybe i couldn't do clear explanation.
          i desolder fat caps.
          changed with normal caps. value's normal.. 1000 mF.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            • Romania
            The problem is they are counterfeit. The good brands are Rubycon,Nichicon and Panasonic. What you have is a counterfeit copy of the Nichicon brand.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • mikail13
              • Aug 2013
              • 93
              • Turkiye
              i don't remember the full name. maybe i'm wrong spelling
              i will control it.
              but pic are here..
              • mikail13
                • Aug 2013
                • 93
                • Turkiye
                Sorry. This is nichicon..
                is this good one?
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Nichicon is a good brand.
                  sigpic
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    The failed caps look like Toshin Kogyo ATWB or ATWY series. You should replace ALL of these capacitors. I have seen tons of them fail on 775 boards, they are very bad series, I've even seen them take out a chipset. What series nichicon caps do you have?
                      • 31015
                      strange that they used shit caps but still put a sepc poly there!
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        ^ They do that so as to get it to outlast the warranty period. And possibly because ultra low ESR lytics have been going out of production for a while now and because polymers have much better conductivity.
                        And yes, TK's ATWY and ATWB series are egregiously bad. Worse than KZG and KZJ and only a notch above Sacon FZ/GSC.
                          by momaka
                          03-12-2025, 03:42 PM
                        • c_corr
                          Asus P4C800-E VRM issues
                          by c_corr
                          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                          This board uses mext ICs and Mosfets in VRM:
                          - ADP3180 PWM controller - in 3 phase mode
                          - ADP3418 as Modfet drivers
                          - High side Mosfets STD38NH02L (from ST)
                          - Low side Mosfets STD90NH02L
                          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                          02-08-2025, 11:59 PM
                          by momaka
                          03-15-2023, 10:17 PM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
