Asus Crosshair Formula V
  • newtothis
    • Mar 2013
    • 1556
    • england
    Right... Killed this motherboard myself by shorting it out. I run my system as a bench rig as I am swapping out GPU's constantly to test after reballing. I switched my motherboard out for another after a socket replacement and while the area was empty I placed a CMOS battery down.... forgot about it and reinstalled the Asus Crosshair.... Switched it on to be met by a spark and system shut down (Battery touched underside of the board near the USB ports)
    Now when attempting to power on if i press the power button repeatedly every now and then the LED's all illuminate on the board and the PSU fan twitches for a split second.
    All fuses on board check fine
    Removing the 8 pin 12v connector make no difference
    How do I go about diagnosing the issue?
    Cheers
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Asus Crosshair Formula V
    Ok update :
    The board attempts to power itself on... lights up, goes off, lights up, goes off... keeps going but the time between it is random, LED's will flicker twice in 1 second... then off for 1 second, then light up once, then stays off couple of seconds.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      Find a schematic and start checking all your power rails for shorts
      -David VanHorn
