ASUS CROSSHAIR IV FORMULA - no reaction + HD LED always on
  • N3Star
    • May 2021
    • 40
    As in the title I've got a problem with that motherboard. At the beginning this board wouldn't POST - it would hang at CPU led, different CPU didn't solve this issue, as well as externally programming entirely new BIOS chip.
    Now it's a bit worse, there is no reaction to power. However, while on stand-by, HD LED is always dimly on, as well as "GO_LED". What links these two lights is IC 6MU1, but I don't think that it's the problem.
    According to the boardview PU2007 regulates VSB just fine, 3.4V on pin 2 and 5V on pin 3, but there is quite a bit of "backfeeding" into PSU on ATX plug - 0.1V on 5V and 0.6V on 3.3V. 5VSB is at 5.14V and power_on(green wire) is also at 5.14V.
    I've got no idea what could cause such behaviour, so any help will be appreciated.
  • anikin73
    • Mar 2022
    • 112
    • singapore
    Re: ASUS CROSSHAIR IV FORMULA - no reaction + HD LED always on
    Revert to old bios. At least the old bios run code... I suspect is your ram or cpu issue,,,how to know. Buy a can of electronics cleaner to spray at the cpu pins and ram pins...
    Also see all cpu pins intact etc
    • N3Star
      • May 2021
      • 40
      Well, no version os BIOS works, since it doesn't even power on. Doesn't even power on without CPU/RAM, and by that I mean that it doesn't turn the power supply on from stand-by. Literally no reaction to power button.
      As for any visual damage, I don't think there is anything missing or broken.
