MSI RD480 Neo2 bad caps
  • Mustang
    • Dec 2003
    • 203
    This board ran fine for over a year with an Opty 144. I decided to upgrade to a dual core opty 170 for folding work and immediately experienced blue screen crashes. The Stock CPU cooler was warm, Northbridge heat sink however was very hot. Visual inspection of the caps showed 7 UC KZG 6.5v 1000uF located near the north bridge to have a very very slight bulge. There's other UC caps of the same rating on the board but these look ok. I replaced the "bad" caps with Panny FM 10v 1200uF and it's folding now . Should I replace the rest of the UC caps? There's 1 behind the USB port, a few between the PCI and PCIe slots and also by the memory slots.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI RD480 Neo2 bad caps
    i would.
    if several are bad all others of that type shoild be replaced.
    btw kzg is an ultra low esr part.
    i wouldnt sub fc at vrm out but probably fine elsewhere.
    • Mustang
      • Dec 2003
      • 203
      Originally posted by kc8adu
      i would.
      Thanks for the info I'll redo them all.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
