Msi desktop board
  • balattc
    • Feb 2015
    • 153
    • india
    Msi desktop board
    MS-7142
    VER:1
    model : K8MM-V
    NO display PLS SEND BIOS BIN FILE
    BIOS bin FILE need
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Msi desktop board
    Have you looked on MSI website in support pages? It should be available to you.
    • Sparkey55
      • Jan 2010
      • 1523
      Originally posted by balattc
      MS-7142
      VER:1
      model : K8MM-V
      BIOS bin FILE need
      You do know that the BIOS files can be found on the support pages of MSI. It took me all of 30 SECONDS using GOOGLE SEARCH to find the info.
      Stop being lazy asking for something that YOU can do that WASTES our time.
      • balattc
        • Feb 2015
        • 153
        • india
        ok ya find it
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • alegatorul
          Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
          by alegatorul
          hi,
          i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
          Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
          I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
          11-03-2024, 02:28 AM
