Generic crap Matsonic PIII MB with Chemicon knock offs
  • Super Nade
    • Jun 2006
    • 294
    This is from a rig in my lab. Thankfully all the experimental data is safe. The board was on its way out a long time ago. It caught our attention only after a few BSOD loops..lol. To make things worse, this board was powered by a Powmax.......
    Most of the 1000uF,6.3V Canicons are dead....
    Also the rest of the crap G-Luxon on the CPU VRM side is dead as well...
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • pvone
    • Oct 2006
    • 11
    Re: Generic crap Matsonic PIII MB with Chemicon knock offs
    reminds me of PC Chips with the cheesy heatsink and Canicons. VRM looks different than the ones I've seen though... anyway, nice
    • Super Nade
      • Jun 2006
      • 294
      PC-Chips..LOL another shit brand I'd avoid like the plague.
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Abit IP35Pro
      ATi HD4870
      • pvone
        • Oct 2006
        • 11
        yep. Personally I don't even bother to check them anymore, straight in the junk box they go. Seen too many issues even with new caps (yes, I recapped a few in the past... )
        • linuxguru
          • Apr 2005
          • 1564
          PCChips is an other alter-ego for Matsonic, ECS, etc. (all are OEM boards from ECS). However, the board will most probably be reliable after recapping and swapping out the PSU for something decent.
          • Super Nade
            • Jun 2006
            • 294
            So it looks like ECS were 100x worse than they are now. Using knock-off caps and G-Luxon's is just criminal.
            Actually mate, the PSU has been running for almost 8 years now without a problem. It seems to be Indy regulated and the caps are pretty decent (Matsushita on the primary, Teapo on the secondary).
            See here:-->
            http://super-nade.blogspot.com/2007/...axwhaaaat.html
            Q6700 @ 3.6 GHz
            Zippy GSM-6600P
            Abit IP35Pro
            ATi HD4870
            • void_ptr
              Bought a bricked 15" generic LCD TV and need firmware
              by void_ptr
              Hi, folks. Thanks for all the work on this site. I am looking for help with a TV. I have a secondhand 15" LCD TV that won't turn on. The board is listed as CV3553M_B24_10 and the panel is a MG1561B01-1. I just want to use it as a portable gamer display and maybe a media player. The branding is "Emerson ETC-1500N" but I know it is a generic Chinese TV. Searching on the internet for compatible files turns up zilch and the ai bots aren't much help. Can someone please help me locate the fw for this TV?
              10-03-2025, 05:23 PM
            • BleedCap
              OLD Socket 478 custom bracket + NEW generic cooler
              by BleedCap
              I already posted this on vogons.
              Its a 3d printed custom bracket for socket 478.
              I used this AM4 bracket as a base design.
              Its to be use with cheap generic clip based cpu cooler.
              Reason for doing this is:
              - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
              - New generic cooler is cheaper and can use bigger fan (less noise)
              I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
              The processor that I was using is P4 2.4Ghz prescott....
              11-05-2023, 08:09 PM
            • linuxrunner
              generic diffuser?
              by linuxrunner
              i have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
              i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
              i checked Samsung parts site but they don't...
              08-26-2022, 10:52 AM
            • Dannyx
              Using car key fob as generic remote control
              by Dannyx
              Good day folks. It's been a while since I've DIY-d anything, so the other day I was thinking if it's possible to use the key fob of my car as a remote for other automation stuff. I have quite a few generic 433Mhz remotes and modules I picked up on Ali for various projects, but instead of having another remote dangling off the key chain, I thought I could use the car's own fob for more than unlocking my car when I'm near it. Say I come home and wish to switch on a light at my front door.
              I already tried putting one of my generic receivers in pairing mode and hitting one of the 2...
              04-18-2022, 02:17 PM
            • itsthatidiotagain
              CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
              by itsthatidiotagain
              CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
              There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
              I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
              A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
              06-23-2025, 03:22 AM
