Hi
What are the views of the forum members as to cap replacement on this mobo?
I should add it is not failing (so far...) and I intend to work this up for production use.
From a physical inspection, I have found the following;
5 of KZE 16V 1200uF 10mm dia, Height 25.4mm, 105 deg C
3 of MCZ 10V 1000uF 10mm dia, Height 15mm, 105 deg C
8 of SME 6.3V 100uF 5mm dia, Height 10mm, 85 deg C
16 of SMG 10V 470uF 5mm dia, Height 10mm, 85 deg C
12 of Nichicon 25V 100uF, 5mm dia, Height 10mm, 85 deg C
4 of Nichicon 25V 220uF 7.5mm dia, Height 10mm, 85 deg C
1 of Nichicon 16V 470uF 7.5mm dia, Height 10mm, 85 deg C
1 of Rubycon 6.3V 220uF 5mm dia, Height 10mm, 85 deg C
2 of Rubycon 25V 22uF 3.5mm dia, Height 10mm, 85 deg C
The ALU (presumed solid) caps are;
8 of can size 10mm dia, Height 10mm - marked as 452 SEPC 560 4
1 of can size 10mm dia, Height 15mm - marked as A 4DT 560 4V
Any advice, help and insight - greatly appreciated
