i bought this board used It appears as someone stated to recap this board but didn't finish it has 2200uf 6.3v rubycon in it and one blotted 2700uf 6.3v cap i wanted to if this was recapped was it done right and if so do i just replace with a 2700uf or a 2200uf capcitor.
recapping a msi 694t pro rev.5
Re: recapping a msi 694t pro rev.5
Yes, you can replace with 2200uF 6.3v intead of 2700uF 6.3v if 2200uF 6.3v is good caps, it is no problem. However, i perfer replace with 3300uF 6.3v D10mm is better if you can't source 2700uF 6.3v caps. -
Originally posted by Big PopeHowever, i perfer replace with 3300uF 6.3v D10mm is better if you can't source 2700uF 6.3v caps.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
by proxneoDear reader
I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
At the moment, I have selected replacements based on the following list of values:
3 x 470uF 10VDC
3 x 4.7uF 35VDC
4 x 47uF 50VDC
8 x 22uF 6.3 VDC
1 x 220uF 6.3VDC
5 x 100uF 6.3VDC
Which...-
by RukyConHello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped... -
by Green Probe(TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
Disclaimer: I'm an amateur hobbyist and will get things wrong.
Always use caution when working around mains power and high voltage capacitors!
Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
SYMPTOMS:
-No display...-
by SatdudeHey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
by slernerI'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets...-
- Loading...
