Msi ms-7613
  • phibs
    • Aug 2013
    • 4
    • Portugal
    Msi ms-7613
    I have a MSI-MS7613 that isn't starting. The PSU is OK, and when I try to start the fan spins once and stops. It starts to do this cycle until i switch it off. I found that a USB port had been shorted, and the respective fuse has blown. Today, it tried to turn on the motherboard without the additional power cord (4 pins) and it's apparently working, which tells me after reading some other posts from this forum that I have a MOSFET from the CPU VRM fried. The problem is to find it. Does anyone have a schematic for this board or any clue how I can solve this problem.
    Thanks.
  • phibs
    • Aug 2013
    • 4
    • Portugal
    Re: Msi ms-7613
    Ok,
    Just figured out that the mobo does not start without the fan connected and the CPU in place.
    Now it starts but nothing happens, no sound, nothing, just the fans running...
    • phibs
      • Aug 2013
      • 4
      • Portugal
      Re: Msi ms-7613
      After some digging, just found that i had some MOSFET shorted. The Major problem now is to find some replacements. Could someone tell me what mosfet can i use. The ones that were in place and are burned are Nikos PO903BD and Nikos PO603BD.
      Thanks in advance.
      • mikail13
        • Aug 2013
        • 93
        • Turkiye
        Re: Msi ms-7613
        first you must change or desolder USB fuse like that
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • MicroSMD Lab
          ASUS ROG Zephyrus GPU Mosfet repeat failure
          by MicroSMD Lab
          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • alro7779
          MOSFET? Is its voltage reading normal?
          by alro7779
          Hello, guys!
          Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
          06-19-2025, 08:19 AM
