MSI RX 5700XT 5v missing
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Hello guys I need a little help here. I'm trying to fix this graphics card regarding it's 5v missing. The card came to me with a shorted buck converter GS9230 (U501) with zero output. I replaced the IC with a new exact same model and the short is gone, but still no output. I checked surrounding components and there seems to be nothing else is at fault as to my knowledge.. I removed coil (L500) to isolate furthermore.
    Thinking that the new buck converter could be defective, I decided to replace it again with a new one but same result. This buck converter is a standalone IC which outputs 5v as gate driver and is powered by 12V bus supply (pin22), which meter reads at 11.99v. I also have 5v in VCC (pin21). Enable, pin2 is at 4.8v (not sure if this is correct). What else do I need to check? I uploaded boardview, schematic and image. Hope someone helps. Thanks!
  • mon2
    • Dec 2019
    • 14717
    https://repair.wiki/w/5V_Rail_on_Navi_GPUs_Explained
    What is the resistance to ground of the output pin?
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      The resistance of the output pins are 9.09 mega ohms.
      Another update. Pin20 (BOOT) of U501 has 4.66v. On R624 pin2 is 11.99v but pin1 has 2.7v going to pin6 (TON) of U501. I tried to read the information about this TON pin but I don't fully understand. Based on the site, I should also check the feedback circuitry and found 0v there. Thanks for the reply.
      • lezsimply
        The Wanderer
        • 657
        • Philippines
        Update on this card. 5v is now present, I found out that the brand new ic's that I used was fake (bought 10 pieces online that came from China) I acquired another 10 pieces from different store and it worked. Unfortunately after replacing the ic again, pwm controller is heating up. I guess I'm stuck here because I know this pwm controller NCP81022 is programmable and I had no idea how to do it. Searched the net and found nothing relevant to this procedure.
        • Manuel S.
          Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
          by Manuel S.
          my Lenovo 720 is dead. :-(
          I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
          Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
          When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
          The EN1 is completely off 0V, EN2 show 1.5V.
          If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
          BS seams SHORT to the OUT....
          03-14-2024, 05:17 PM
        • jm1234
          Reolink RLC-410-5MP - buck convertor
          by jm1234
          it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
          Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
          07-14-2025, 04:30 AM
        • caspian
          Too much current from a Buck Converter
          by caspian
          Dear members,
          Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
          Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
          PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback...
          05-29-2020, 06:41 AM
        • adamski1952
          ps5 shorted after buck converter
          by adamski1952
          Hi.all.
          Working on a PS5 EDM-010 motherboard and i've located a short after the TLV62090RGTR 5v to 3.3v chip directly behind F7002.same chip i think. I've removed the chip thinking that was the problem but the short is still there.I injected 1v at 1 amp on output coil (arrowed in picture) but nothing shows up on my thermal camera. No boardview so I because I dont know which rail it feeds i'm reluctant to up the power injection.I could use some help with this if anone has any ideas. ...
          12-18-2024, 08:25 PM
        • Thetechdude
          Repair help. Zotac trinity 4070ti 12G 3x
          by Thetechdude
          Hi Guys.
          Here I have a 4070ti with some issues.
          When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
          Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
          Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
          Resistances:...
          09-07-2025, 07:49 AM
