8RDA+ with bad caps
  • raz1337
    • Nov 2004
    8RDA+ with bad caps
    For the last year and a half I've been running this system:
    Epox 8RDA+ Rev 1.0
    Athlon XP 2500+ Barton
    PNY Geforce 4 Ti 4600
    2x 512MB Corsair XMS PC3200
    Antec SL400 PSU
    The first month or so, I spent overclocking and hitting my proverbial wall, which was 200x11, with 2-3-3-7 timings.
    Six months ago, I ordered a Gainward Geforce FX 5950 ultra to upgrade, and I installed it. When I was installing it I noticed a black residue on the top part of the ATX connector in the motherboard inside of the plugs. I honestly didn't know what to make of it so I kind of ignored it.
    I installed the FX 5950 and had no problems for a few days. Then I started having graphic glitches when starting windows, I would get all funky pixels and colorings when at the Win2k loading screen. I switched back to the Ti 4600 and I had the same problem.
    After a few days of troubleshooting, I just went out and bought an Antec True430 and that seemed to fix the problems. I used the FX 5950 for a week or so. Then I started freezing while playing games forcing a cold boot, getting jittering noises in my speakers when it froze. I switched to the Ti 4600, and the problem disappeared. I RMA'd the FX 5950, and I've been using my computer the last 5 1/2 months without a hitch.
    Last week, I switched my desks, I powered off the computer, didn't unplug the power cable from the back of the box, placed the monitor on the floor, switched desks, and put the monitor back on the floor. When I booted up, I got "inaccessible boot device" errors, sometimes the windows 2k loading screen would freeze, or windows would freeze while loading up.
    After trying to check for loose connectors and plugs, I narrowed it down that I couldn't run with my overclocked settings anymore and prime95 had become unstable, when it had ran perfect over a year ago with the overclocked settings. After doing more researching, I found out about the potential bad caps problem, and, you guessed it, I checked the caps and some near the CPU were bulging, and there was a tiny bit of an orange residue/substance on the top of 2 of them.
    Over the weekend, I've had the computer off in fear of it affecting any of the others parts, and because of this, I went ahead and just ordered an Abit NF7-S rev 2.0, which should be here tomorrow. During all this commotion, my FX 5950, which I RMA'd 2 months ago, just now arrived at my doorstep, a brand new one from Gainward.
    So, tomorrow when the new board comes, I'll be rebuilding my computer with the new board and hopefully finally being able to test out the new video card.
    There are some things making me nervous right now about the inevitable rebuilding of my computer.
    Could any of the other pieces of the computer have been affected by the bad caps problem?
    Was the black residue on the ATX connector from a bad PSU, or from the bad caps deteriorating?
    Could this have also caused the instability with the FX 5950?
    Am I heading toward any possible problems tomorrow with the processor, video card or the PSU?
    This is the first time this has happened to me, and I don't know what to expect.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    sorry nobody replied, this is abnormal. I hope your new board has arrived and you are happy with your new setup. You are lucky to get a new graphics card, whether the original was bad or the tech did not even check it, who knows.
    Anyway you have a new unaffected card so forget that. Run tests on your new setup, it posts, it passes memory test software, the hardware is good.
    it could be worse, your hardware could look like this :
    https://www.badcaps.net/forum/viewtopic.php?t=221
    check this thread about epox and burnt atx
    http://www.aoaforums.com/forum/showthread.php?t=23785
    check the forum about ANTEC psu
    ANTEC SL300S 300W RTL badcaps
    https://www.badcaps.net/forum/viewtopic.php?t=154
    Antec True430 ATX Supply BAD CAPS ARRGGHH!![NOT 56K FRNDLY]
    https://www.badcaps.net/forum/viewtopic.php?t=145
    dont worry i have not seen any psu with quality caps. did you open your psu to check the caps there also?
    you will be fine, you probably caught the problem just in time. if a cap had shorted it would have been a whole lot worse. Tell us how your new system is doing.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • ajdrenter
      Picking caps for Antec SU-380
      by ajdrenter
      In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
      https://www.badcaps.net/forum/showthread.php?t=14159
      It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
      05-13-2023, 10:40 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
