MSI A520M Motherboard No Power with Processor. When remove processor all voltages are genarated ....my processor is compatible this motherboard ...i want to help to repair this
The CPU communicates during POST with the CPU VRM controller to generate all powers correctly. This is part of the bios POST program. For each CPU model the setup of the VRM controller might have different parameters. So bios must know the CPU to setup VRM correctly. Maybe your bios is too old, not supporting your CPU? Another reason could be corrupted bios. Try another CPU, supported by first release of bios. Try upgrade bios with this CPU. If you don't have access to such CPU, backup bios and program newest stock bios with hardware programmer. Take off CPU and depower motherboard to do this. If this will work bios DMI data should be transferred from old bios to new one, check also if motherboard still has a valid MAC address, if not then it also must be transferred from old bios to new one (usually it is on address 1000h in the bios).
If this will not help there must be an hardware issue with the board, most probably with the CPU VRM network, some defect device, or missing smd, cut through track, etc., or your CPU is just defect.Last edited by DynaxSC; 06-18-2025, 03:45 PM. -
Try different memories. Try only one memory, alter slots through all available.
Examine socket/cpu for demages/bent/missing pins.
Short J1 jumper if present on this board (unique feature for majority of MSI boards), this should force the cpu vcore enabling, check then if vcore present. If not, this will mean that something in the cpu vrm network is broken and the vrm controller switches into blocked/safe state. But even if you get vcore this way, board will most probably not POST, as there is some issue present.
Examine board very detailled for missing / ripped off smd devices (resistors, caps), first in neighbourhood of mounting holes, second rest of board. Start with backside. Same for cut tracks. Look for really tiny demages, eg. coming from the top edge of a fallen screwdriver - track cut, demage can be smaller then 1mm, almost invisible to the eyes. Use some x15 magnifier glass. Even an smd resistor can be still present, but broken into two parts and not conducting any more. This is very weak visible, but I have seen such demages already a few times.
If not find any missing devices then measure all supply voltages on the coils, when any is missing then examine if respectivelly vrm controller gets Enable signal. If one has Enable, but no voltage present, vrm might be broken.
Check also all low ohm serial "fuse" resistors (usually 0-2,2 ohms).Last edited by DynaxSC; 06-20-2025, 05:38 PM.Comment
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
Assuming...7 Photos -
by iulik17dHello everyone!
The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
This specification for the DELL Latitude 7280 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7280 boardview and 7280 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7280...09-06-2024, 06:10 AM
- Loading...
