PowerEdge R740 coil resistance
  • lerom
    • Oct 2020
    • 7
    • Auvhan
    can anyone measure the resistance on coil L12 3.3V (near USB, EMMC chip) and coil L46 1V near CPU1 ?
    thanks.
  • Jane
    What is the lowest acceptable resistance on a coil without considering a short on PCB
    by Jane
    I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
    Thank you.
    02-27-2024, 01:42 PM
  • cind12
    GTX 1080 TI Gigabyte Aorus low resistance on vmem
    by cind12
    Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
    Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
    The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
    Resistance on 12V 4K ohms (Power present when on)
    Resistance on 12V PEX 4K ohms...
    12-08-2023, 09:09 AM
  • andrew25
    Dell PowerEdge R740 bios
    by andrew25
    i have 4 Dell PowerEdge R740 servers, they all have same problem of no display on monitors. they all power up and running okay but nothing displaying on monitor, am suspecting server attack... i attached 1 bios dump and an update exe from dell website, if anybody can rebuild new bios i will really appreciate..
    mobo ID: F6MXH
    Service Tag: CSPF903...
    02-07-2024, 12:53 AM
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • bpjl
    Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
    by bpjl
    I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
    I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
    During the inspection, I noticed a burned (charred on one side) double diode PD817.
    Voltage drops during PD817 measurements:
    - PIN1-PIN3 forward biased = 0.137V...
    01-27-2025, 03:01 PM
