Hmm GuYS itS Me AgAin.... Actually my CPU temP stays at 50'C and Not even changing or controlled ...Id change the Caps ,still same problem came out even i load to default cmos...im wondering Is it the MOSFET problem or ceramacic caps (center of the socket procs) ...cause what i see the Flux around the Ceramic caps... that what i afraid of...
Msi 6547
Re: Msi 6547
Flux is not conductive and is usually there as a residue. Flux will not cause problems. Whenever there are problems reading temperatures on motherboards, I always look for an updated firmware. Many times this fixes any temperature related problems. Thou I have never seen a problem with the temperature sitting on a particular value. I doubt it is a MOSFET problem, although this is much much more likely than the flux around capacitors.
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo -
by chth96I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
Is it good to use chemistronic flux off es835b for flux remover?
Or I have to purchase "3m novec flux remover" which is quite expensive in my nation? -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... - Loading...
