Replacing OST caps on Microstar KT6 Delta motherboard
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    #41
    Re: Replacing OST caps on Microstar KT6 Delta motherboard
    Originally posted by socketa
    Can someone please help me find a replacement output choke and a couple of mosfets since i'm getting ready to make an order for parts
    (reason for replacing these parts is that i broke the choke and the mosfets have diode readings of 0.034v and 0.072v, on diode test mode)
    If those readings are taken with the MOSFETs on the board, you probably have something else affecting them as these don't look very meaningful. But anyways, I guess it is better to grab a few spare MOSFETs than to ponder whether the ones on the board are currently shorted or not.
    i can't find any replacement choke
    HERE, that is 1.1uF / 25A
    (although there is lots of toroidal inductors that look like it)
    The choke is labelled on the vrm schematic as 1.1uH / 25A
    ^Wrong link?
    Whatever you linked to does not list 1.1 uH, 25A choke. In fact, the lowest I see for through-hole inductors is 5.6 uH, which is a bit too high. SMD does have 1.1uH, but the current is way too low. However, I did find an SMD inductor rated for 1.2 uH and 25.4A here:
    http://nz.element14.com/bourns-jw-mi...-20/dp/1180547
    That should work, though, you may have to solder leads to it (preferably very thick ones) to attach it to the board (actually, it would probably be easier to solder the thick leads to the board and then the inductor to them). Kind of ghetto, but should work.
    Also, I suggest you count the number of turns of wire on the good inductor and post it here. Should help with finding a proper one easier... or worst case scenario, use that info to pull something from another dead motherboard. Whenever you see inductors on PC hardware that might say something like "aRb", that means a.b uH (where "a" and "b" are single-digit numbers). Similarly, "Rab" translates to 0.ab uH.
    Or worst worst case scenario - run the board with just half the VRM phases - i.e. with the broken choke (and associated MOSFETs) removed from the board. But a high power CPU could overload the other working VRM phase... so yeah, best saved as a last resort.
    Both mosfets have this printed on them:
    D432AN
    FDB
    6670AL
    i think that it is a fairchild mosfet
    So, would it be OK to use THIS,
    as, in the component description, there is a note saying that this is a replacement for it.
    ^Yup, that's a Fairchild MOSFET. Part number is FDB6670AL. The MOSFET you linked to is a bit under-specced on the DC continuous current, but it has a higher pulse current, and same Rds(on) resistance, so it should work just fine. However, do note that what you linked to is a TO-263-3 case and not simply a TO-263. That means, the middle pin on the MOSFET is not cut off, so you probably will have to cut it yourself. But that shouldn't be a problem.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 661
      • samsara
      #42
      Those readings were taken with the mosfet legs desoldered.
      They both switch on and off OK using the multimeter diode test mode.
      But when i tested the mosfet diode reverse bias, those were the reading that i got - so was suspicious, because one was double the value of the other one, and the other two mosfets (15N03L) in the VRM both give reading of around 0.5V
      That was the right link.
      It was provided it to show where i was looking for the choke and that there was none that had a similar inductance/current rating, and that perhaps i had interpreted the inductance wrongly.
      Shirt outa luck HERE also
      Have provided a photo of the choke
      It has 5 groups of 3 windings
      i don't have any other broken motherboards with similar chokes
      Just a gigabyte board with different sized chokes and windings (2nd thumbnail)
      Was surprised that there was no chokes anywhere near the stated 1.1uH value - which usually means that i'm doing something wrong.
      Thought that they would be reasonably common - but am now suspecting that they would have being custom made
      Short of using that surface-mount choke, would it be better just to put this board away until i find a broken motherboard with a matching choke?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4954
        • New Zealand
        #43
        Most likely, very often they are custom made.
        -David VanHorn
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          #44
          Did you discharge the Gate before testing the MOSFET diode? If shorting all pins with your finger doesn't do it, try shorting Gate to Source with a piece of metal, then try measuring again.
          Well, the schematic calls for 1.1 uH, so you did interpret it right.
          Given that most inductors have 20% tolerance, going up a notch to 1.2 uH shouldn't be a problem at all.
          The 3 wires are all grouped together to form one thicker wire. Looks like a 5 turn inductor.
          The chokes on the Gigabyte look like 5-turn as well. If the choke toroid is the same size (well, more or less), this may work, especially since that board looks like it's from the same era.
          But IMO, that's more of a crapshoot than using the 1.2 uH coils. Plus, if you are buying the replacement MOSFETs, you might as well grab two of those coils (and I say two so that you can replace both on your motherboard, just in case something doesn't work out).
          Thought that they would be reasonably common - but am now suspecting that they would have being custom made.
          It may or may not be custom made. However, I often find that many motherboard manufacturers usually make one VRM design, and then they use it on almost every motherboard that they make in that given era. So it's very unlikely that the design on your specific motherboard model is unique. Most likely, other Microstar motherboards from that era use the same coils.
          It's unlikely that you will find a perfect-matching choke (actually, chokes may sometimes look a bit different, but they could still have the same inductance and current handling capability). The surface-mount choke should work... the motherboard just won't look quite "factory made". But there's beauty in that too .
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 661
            • samsara
            #45
            Thankyou for that
            i looked at that surface-mount inductor, and it looked quite different - so was skeptical.
            But now i feel confident, and combined with your last statement, inspired, that is OK - unfortunately minimum order is 77
            Sorry for those mosfet readings - must have being getting a bit tired when doing that.
            It wasn't ohms, and also wasn't the diode reverse bias - i was talking shit
            OK,
            i shorted the gate to drain, and they all return a reading from 0.5v to 0.6v for "forward voltage drop of mosfet body diode" (voice in mosfet testing vid) - which is similar to the other two.
            What i initially should have said, was that after turning the mosfets on (+ve to G and -ve to S), and then returning the +ve lead to D, i got the following readings:
            0.084v
            and 0.039v
            The other two (which, when the pins are soldered to the mobo, would have their drain connected to the input caps) give readings of around
            0.509v
            and 0.549v
            Does that indicate any cause for concern?
            i now notice that there is a consistant difference between both couples of mosfets of about 0.04v, and perhaps that is due to the gate still being soldered to the board?
            i'm kinda getting the feeling that these mosfets are testing OK
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 661
              • samsara
              #46
              The mosfets are not shorted
              • Agent24
                I see dead caps
                • Oct 2007
                • 4954
                • New Zealand
                #47
                It still doesn't hurt to have spare parts, especially if getting more quickly will be inconvenient or pricey. When I buy parts I typically buy more than I need.
                -David VanHorn
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #48
                  Thankyou for that
                  Lol, now that's a downer.
                  I'll look through my box-o-coils and PM you if I find any suitable ones. Maybe easier if I just mail you a few .
                  OK,
                  Sounds reasonable.
                  In these tests, I suggest shorting G to S, though, and not D. Shorting G to D may not always discharge the Gate properly.
                  Yes, quite possible.
                  Well, I do recall your motherboard was turning ON (or at least running the fans and the PSU, that is). If a MOSFET was shorted, that would usually shut down the PSU as well.
                  I have spare MOSFETs as well, though they are the smaller TO-252 ones and not TO-263.
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 661
                    • samsara
                    #49
                    Yes, i definitley did short G to S
                    (at the time of typing that, i was thinking of the schematic, rather than the physical pins, and got mixed up - sorry)
                    Will be on to this some time next week
                    Might even temporarily just use the old broken choke - as i'm thinking that it should still work, even if a section of the bottom of the ferrite? ring is missing.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4954
                      • New Zealand
                      #50
                      Might even temporarily just use the old broken choke, as i'm thinking that it should still work even if a section of the bottom of the ring is missing.
                      I wouldn't, in that application it could throw the circuit stability out of whack and cause more problems.
                      -David VanHorn
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #51
                        No, you can't use that choke with the broken core. Any time you introduce or increase the air gap in a core, that changes the inductance. If you had all of the peices from the broken choke and you glued them back very tightly, the inductance may or may not change too much, and the motherboard *might* just work, but I still would discourage you from doing that (unless you feel experimental ). Though I doubt anything major is going to happen if you mismatch the inductance - most likely the voltage regulation will be off and the motherboard will refuse to boot.
                        Anyways, I checked my stash... and all I have is 4-turn chokes from Xbox 360s. Don't know what inductance they are, but the turns are made from three thick wires, so at least they should be able to handle the current.
                        I also have 1.2 uH chokes from an ASUS LGA1156 motherboard (they are on CPU VRM), though I don't know their current-handling capability and they look a bit small.
                        I guess if you can't find anything, let me know. I can either pull out and send you those 1.2 uH chokes or I can send you the 4-turn chokes from the Xbox 360s and you can either re-wind them with 5-turns with the wire you have from your broken choke or you can use the 4-turn chokes as-is (in that case, you must replace both on your motherboard, becase it would be better if they match).
                        I also have MOSFETs and caps - again, Xbox 360 pulls, but they are all working. Could send them with the coils.
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 661
                          • samsara
                          #52
                          Thanks, momaka, for the advice, and the offer to send the parts.
                          Yes, i thought about re-gluing the broken section, but only after throwing it out.
                          Doh!
                          Will first overcome a reluctance to deal with humans, and fear of rejection, and go to the waste recycle depo and ask if i can have a scrounge.
                          That makes a lot more sense, than you posting parts.
                          Will post back here when i have put the new caps and chokes on.
                          Cheers
                          • socketa
                            Asbelowsoabove
                            • Jun 2014
                            • 661
                            • samsara
                            #53
                            Removed the other choke, and then tested the other (non-VRM) side of the chokes to ground:
                            27 ohms with no CPU installed
                            4 ohms with cpu installed
                            Looking at the pictures for this board, I don't see a separate buck circuit for the Northbridge, so it is possible this is one of those few boards that powers its Northbridge from the CPU V_core rail. Therefore, don't be alarmed if the "lower" MOSFETs appear shorted even with the CPU removed.
                            So, that 27 ohms is possibly quite normal.
                            Pulled a choke from an artifacting nividia video card, which had same size toroid and number of turns, but slightly thicker wire, and used that to replace the one that i destroyed.
                            Tested the caps, and they all had good capacitance and ESR - so put them back in.
                            Re-soldered the VRM mosfets, since they were not shorted, and tested in agreement with the schematic (also noticed that the output mosfets are paralleled with another pair that are not on the schematic)
                            Put the CPU and heatsink back on, and connected power supply.
                            Pushed power button and the CPU fan was spinning and the keyboard flashed it's lights as normal.
                            CPU got hot
                            Also the green front panel power LED lit up
                            Checked the voltage to the CPU it was 1.68V which seems about right power for a Barton 462 processor (Spec = 1.65V)
                            But that was it, - no beep, or boot into BIOS
                            Powered off with power button
                            Tried again several times - No change
                            So turned it off, cleared the CMOS with the jumper (just in case that was causing the problem)
                            Now the motherboard doesn't respond when the power button is pressed (no CPU fan and CPU cold)
                            Checked that the CPU was OK in another motherboard - yep OK
                            Removing the 12V CPU plug makes no difference
                            Something is stopping the power button from starting the PSU
                            There is 3.3V on the power button positive pin.
                            On the ATX female connector, there is 254 ohms to ground on the 3.3V rail.
                            i compared with a couple of other MSI socket A boards and there was no connection to ground whatsoever on the 3.3V rail.
                            So perhaps this is a hint as to what is causing the problem?
                            Odd that it was half working, until i reset the BIOS.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #54
                              Do any of the fans in the PC twitch or move for a second when you press the power switch?
                              - If yes, you have a short-circuit somewhere. That 254 Ohms to ground on the 3.3V rail could be it.
                              - If no, rest CMOS again. maybe even try without CMOS battery. Also check your CMOS reset jumpers - if you forgot it in the reset position, the motherboard may not boot. Lastly, check voltage going to the Southbridge and LPC/Super IO chip.
                              • socketa
                                Asbelowsoabove
                                • Jun 2014
                                • 661
                                • samsara
                                #55
                                No, the fans do not twitch - they remain absolutely still.
                                Yes, have tried resetting the CMOS several times now - with, and without, the battery.
                                The jumper was returned back the "Keep Data position"
                                There is voltage on the PSU green wire of 4.97V
                                5VSB : 4.98V
                                Winbond W83697HF LPC chip:
                                VCC Pin 5 = 0V
                                VCC3V Pin 22 = 0V
                                VSB Pin 99 = 4.98V
                                VBAT Pin 102 = 3.60V
                                AVCC Pin 105 = 0V
                                (Just noticed that there is dots on the board that aid in the counting of the pins - that makes things a lot easier)
                                Think that i found the rail that powers the South Bridge
                                The MSI schematic shows that the VCC33 pins of VT8235 (the one on this 2.0 version board is VT8237) is connected to an electrolytic capacitor, EC44 - and there is no voltage present there
                                Also checked the voltage at the Bios Jumper, and get 3.60V to ground
                                P.S. What is meant by low pin count? - obviously, it's not referring to the number of pins.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4954
                                  • New Zealand
                                  #56
                                  https://en.wikipedia.org/wiki/Low_Pin_Count
                                  Do you get something between 3-5v on the PWSW+ connector at front panel?
                                  -David VanHorn
                                  • socketa
                                    Asbelowsoabove
                                    • Jun 2014
                                    • 661
                                    • samsara
                                    #57
                                    3.28v
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      #58
                                      VCC33 on the VT8235 in the schematic connects to VCC3. And if you look at the ATX connector on page 43, you will see that VCC3 is the 3.3V rail on the PSU. Since the PSU is not turned ON, then there would be no VCC33 going to the VT8235.
                                      That said, the VT8235 has two other type of power pins: VSUS25 (which connects to VSUS2_5 on chematic) and VSUS33 (which connects to 3VDUAL point on schematic) - as given on page 18 and 19. Check what voltages you get for these two.
                                      3VDUAL can be found on capacitor EC14 (supposedly a 1000 uF, 10V cap), and is generated either by Q16 when system is powered OFF/standby or Q25 when system is ON. (Page 42 bottom.)
                                      VSUS2_5 is derived from 3VDUAL through Q39. (Page 39 bottom.) However, I am not sure if VSUS2_5 should be present without the PC being powered ON. Therefore, I think only 3VDUAL should have 3.3V on it at all times, regardless of what state the PC is in.
                                      Same goes for VCC2_5 as for VSUS2_5.
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 661
                                        • samsara
                                        #59
                                        Appreciate you checking that out, and the explanation.
                                        Am assuming that you meant page 42?
                                        (Just checking that we are looking at the same document)
                                        EC14 has 3.3V on it
                                        And EC36, which is connected to VSUS2_5 (page 42) has 2.15V on it
                                        VCC2_5 (same page) is connected to EC31, which has 0V on it.
                                        Something that may, or may not, be worth mentioning:
                                        When i was checking EC14 +VE to ground, i heard a noise like a small fly that had being hit with fly-spray when it's spinning on its back, and it stopped as soon as i removed the probe
                                        When i tested it again, there was no noise
                                        No smoke or smell.
                                        I had the backside of the board vertical, and towards me, and the PSU and CPU fan on the other side, so they were obscured from view. Swapped the CPU fan just to see if that was causing a fault - but changing it made no difference.
                                        No flys or fly-spray in the house.
                                        Possibly just a fluctuation of the quantum vacuum?
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #60
                                          EC14 has 3.3V on it
                                          Ah yes, page 42 indeed. (I did it again! Thinking of one thing and typing another. Maybe I need to start taking )
                                          Anyways... So with 3.3V on 3VDUAL, then the SB (VT8235) is at least getting power there.
                                          Now, that voltage you got on VSUS2_5 seems a bit low. You should get +/-5% at the most. So that's 2.375V for the lower limit. I don't know if that is indicating problem with something pulling too much power from VSUS2_5, thus causing it to sag, or if the LM358 (U12A) is bad (or maybe some voo-doo black-magic causing your multimeters to be off?... even though we already checked that they work right in the ASUS P5VDC motherboard thread). I guess you should check the reference voltage (VREF1_25) on that LM358, pin #3. I think VREF1_25 is generated by that MSI-5 ACPI controller.
                                          Also, while looking at that LM358 op-amp, I kind of wonder what voltage does "9VSB" have. It seems like another voltage generated by that MSI-5 IC. I can see, however, that when the PC is running, that "9VSB" becomes 12V because of diode D11.
                                          All of this is on page 42, by the way (both for my reference and yours)
                                          Well, I will only *guess* that VCC2_5 is meant to be off, since we do have 2.5V on VSUS2_5 (well, not quite, but it still counts, I suppose).
                                          No smoke or smell.
                                          I'll go with that last one. I literally have no clue what could have happened there . Still, observations like that are always worth noting nonetheless, as that implies you are a careful tech with attention to detail.
                                          I sometimes get quite annoyed (and eventually amused too) by having to fix something after other careless "tech" had worked on it. If I see missing or misplaced screws, that's usually a good hint of what to expect .
                                            MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                            This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
                                          • glovecaps
                                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                            by glovecaps
                                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                            11-25-2024, 04:23 PM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
