ADATA XPG SX6000 Data recovery
  • mr3
    • Aug 2024
    • RO
    Hey,
    I have some data on a Adata .M2 SSD that I will like to recover(a got a quote for 650$), the drive has 3 pin header on one side.What programmer do I need to read the data.The device powers one no PCI device when I run lspci but controler heater up not to much.
  • mr3
    • Aug 2024
    • RO
    Photo of drive
    • edugimeno
      Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
      by edugimeno
      Hi!!
      Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
      I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
      At a certain point, moving stuff around, I put all wires back in place and...
      03-24-2024, 02:31 PM
    • volinakis
      Chromebook recovery failed - how to fix it
      by volinakis
      So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
      Finally I found a site where they suggested to try with an older image and ... it worked!
      What I did:
      - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
      09-18-2023, 03:26 PM
    • madan1
      Diesel heater emergency power supply / poor man's UPS
      by madan1
      Hello everyone.
      Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
      12-18-2022, 08:05 PM
      Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
      by sam_sam_sam
      I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
      I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
      12-16-2023, 08:39 PM
    • myth77
      macbook pro a2141 can not make recovery
      by myth77
      So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
      So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
      06-19-2022, 11:21 AM
