Replacement for 8mm diameter CapXon KF series
  • GnatGoSplat
    • Jul 2011
    • 50
    I need to replace some CapXon KF series capacitors which are 8mm in diameter on an Antec BP500U PSU. I believe Nichicon HE is the closest electrical equivalent, but they don't come in 8mm diameter. I'm afraid to use HM because I don't want to increase ripple.
    Are there any good caps that cross to the KF series that are 8mm diameter for 1000uF 16V?
    I suppose I could use 10mm caps if the leads are long enough, they would have to be suspended above the other components because they wouldn't fit where the original caps used to be. I noticed the secondary caps are pretty well gooped and glued to prevent vibration, would suspending the caps high above the pcb result in a lot of annoying whining/squealing noises?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Replacement for 8mm diameter CapXon KF series
    Yes,
    Here are some series suitable for PSUs that have that cap in 8mm:
    Rubycon ZLH
    Panasonic FR
    UCC KZH
    UCC KZM
    Nichicon HV
    I wouldn't elevate the caps off the PCB. You're right not to use HM class caps for this application.
    • GnatGoSplat
      • Jul 2011
      • 50
      Thanks! I think I'll go for the Panasonic FR. 9000hrs@105C.
      Yeah, I've read that cap leads should be kept short as possible due to inductance.
        by momaka
        03-15-2023, 10:17 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
      • rewease
        Replacement for the Siemens Bakelite caps in an early 1980s SMPS
        by rewease
        There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
        Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
        Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
        09-17-2023, 12:53 AM
      • crosswinds
        Assistance with identifying replacement caps on ASUS P5VDZ-MX
        by crosswinds
        So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
        Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
        Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
        Its a ASUS P5VDZ-MX board.
        I would really appreciate some assistance on what the best replacement caps would be for these:
        Panasonic(M)...
        04-17-2024, 04:25 PM
        ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
        This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-12-2024, 03:28 PM
