Picked up a used MSI Ventus 1660 super with no video output for $50 to dip my toes into GPU repair. After some lurking around here, google searches, and youtube videos, I've gotten around to checking resistances, and checking for the base and minor rails. On first inspection, I didn't any shorts on any rails, so I powered up the card, and found the 5v, 12v, 5v, 1.8v, and Vcore(I hadnt found the 3.3v location at the time). Later, after finding the 3.3v, I got a pcie extension and powered up again. This time I found the 12v. 5v, 3.3v, 1.8v, Vcore, and Vmem. Later, when I wanted to doublecheck my voltages, all the rails weregone, exceptthe 12v. At no point during the 3 times I powered on the catd was there any video, but the fans always run at full speed when they are installed and the card is powered on. Any tips? Could something be intermittently failing? Also, I'm not sure where of if the pex rail is, so I don't know if it's working. I also don't have a boardview or schematic for the card.
First GPU repair project
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
by skwarszczowHello everyone,
This is my first post on the forum
I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
Before completing the purchase, we decided to erase... -
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
by InstafixxHi,
Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
I checked the Power Sequences below and found this -
Once a valid external power source (Charger or battery) is connected, the following rails will come online.
PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced... -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
- Loading...
