Qnap TS453 Semi Working Motherboard , though 12V to two disks only
  • 90Ninety
    • Aug 2011
    • 86
    • UK Mains Voltage 240V 50 Hz
    Hi
    I have a 453 Mini , two of the four Sata ports are not getting 12V . I am wondering if anyone has knowledge on hardware repair on these devices . I have attached an image of the board , it appears the Sata ports are powered in pairs , the right pair are working , left pair no voltage ( 0.2V)
    I have tried tracing the 12V rail , though have not been successful . I am guessing there is a Transistor or Mosfet that is open
    Any help , perhaps a schematic?
    The board otherwise appears to work fine .. Boots up ,
  • 90Ninety
    • Aug 2011
    • 86
    I suspect , that this component 4955GM ( MOS?) is the culprit
    . Since on Pin 1, 2 & 4 have 12V Then pins 7 & 8 go to the 12V on the Sata on the 2nd slot ( non working) .. Though I cant seem to find a trace to the 1st slot 12V . Perhaps I will replace this , then see ..
    Also this looks suspicious ( WRA D33​) , though not sure what it is, seems to be a much higher resistance compared to the others next to the working SATA ports
    WRA D33​
    • 90Ninety
      • Aug 2011
      • 86
      Seems the markings on the components are not clear .. Perhaps the alcohol wash removed them
      Cant seem to find anything definitive on the marking I can see , what are 4955GM & WRA-D33 .. Unless I have recorded them incorrectly ?
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        You can try to deduce the circuit ( and pin voltages ) from the functioning pair of ports
        • 90Ninety
          • Aug 2011
          • 86
          I replaced the 4955M Power Mosfet , though this makes no difference . There is something stopping the mosfet from sending the 12V to the SATA port ..
          • glovecaps
            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
            by glovecaps
            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
