Sapphire HD 7870 possible short
  • mikkhh
    • Jun 2016
    • 13
    • Estonia
    #61
    Re: Sapphire HD 7870 possible short
    I tested everything else on the card and if somebody wants a picture about the shorted mosfet, well there it is. But the gpu memory mosfet itself could be just fine at the worst case of scenario. The short could be caused by GPU memory itself (atleast half the rams are dead) or the memory controller within the GPU die. I will solder the mosfet off and report back then. Let´s hope for the best. BTW that shorted mosfet is very very common AMD cards and most likely it is the faultty memory controller within the gpu die .
    • AMD_Ripper
      • Jun 2016
      • 6
      I didn't read all but did you fix the 7870 ?
      • AMD_Ripper
        • Jun 2016
        • 6
        What's the sense is signing up to a forum if you can't post anything.
        • CroTech
          Student
          • Dec 2012
          • 149
          • Croatia
          #64
          Hi guys,
          So my XFX R9 380 was working fine but I wanted to put it to my cheaper/weaker PC since I got upgraded, everything was working fine, but I think my generic PSU killed it somehow.
          I installed the GPU and it turned on ok, started playing a game and suddenly black screen.
          I restarted PC but the GPU seems to be as if not pluged in.
          Took the heatsink if and saw the connector terminals are shorted, spotted these 2 MOSFETs shorted and replaced them with indentical, nothing changed.
          There is a short somewhere but I dont know where.
            master hoarder
            • May 2008
            • 12175
            #65
            So with the video card in the computer and the PCI-E power connectors plugged in, can you turn On the computer without the PSU shutting down instantly? If yes, then you might not have a short-circuit. A short-circuit on the GPU V_core or RAM Vdd usually pulls down the whole PSU and causes it to shut down. If that's not the case, you probably have a GPU BGA/bumpgate problem.
            • CroTech
              Student
              • Dec 2012
              • 149
              • Croatia
              #66
              With the video card plugged in the PCIe, and both connector from the PSU to the Video card the PC turns on, works well on the integrated GPU and it boots normaly even thoguh Ohm meter shows 1 Ohm on the marked terminals.
              The GPU did not have any problems so far with the BGA and has not been "oven repaired".
              Also I would like to add that while the PC is on, the heatsink is cold and the GPU is not developing any heat.
              So I would say that the GPU chip is not shorted, however I do not understand how can the PC boot and work if there is a short anywhere in the PC, in my caste the video card connector is shorted (or is it)?
                master hoarder
                • May 2008
                • 12175
                #67
                If you had a shorted MOSFET like you say, then the PC would NOT turn On. Reason being is the GPU (and sometimes also the RAM) has a very low resistance - typically less than 10 Ohms (usually around 1-3 Ohms on recent GPUs). Thus, a shorted upper MOSFET will cause the GPU chip to try to draw an extreme amount of current from the PSU. This will almost always trigger the PSU's short-circuit protection (the few cases where that didn't happen, I saw the GPU shoot up smoke like a Diesel truck, but only white in color and with a TERRIBLE smell ).
                So check that you are measuring the pins in the PCI-E power connector properly. On a 6-pin and 8-pin PCI-E power connector, the row of 3 (or 4) pins on the side of the lock/latch are ground. The 3 (or 4) opposite of that are 12V. Have a look on Google for a diagram.
                Also, note that on an EPS12V connector (those 8-pin CPU connectors), the ground and 12V pins are completely the opposite to that of the PCI-E power connector: the row of 4 pins closer to the connector lock/latch are 12V and the other side is ground. So keep that in mind while measuring.
                Finally, make sure you keep your multimeter probes connected long enough to measure the resistance. Due to capacitors in the circuit, your multimeter might show a low resistance of a few Ohms for the first 1-2 seconds. But if you leave the probes connected long enough for the caps to charge, the resistance should rise (typically it will be more than 1 KOhm with the video card removed from the motherboard and disconnected from the PSU). And last but not least: make sure you are not misinterpreting your multimeter (especially if it's a manual-range one) - a "1" on the left side of the screen does NOT mean the resistance is "1 Ohm". It means "over range of the current scale". I've seen people make this mistake, so I am hoping that's not what's going on here.
                That said, just because the video card didn't have BGA/bumpgate issues up to this point and was never oven-baked doesn't mean that it couldn't have just developed them. Given the symptoms you describe and the fact that your computer can run without the video card shorting out the PSU strongly suggests BGA/bumpgate issues.
                • CroTech
                  Student
                  • Dec 2012
                  • 149
                  • Croatia
                  #68
                  Momaka, you were right, after leaving it for a 2-3 min the caps charged and the measurements are different, here are the photos, the same thing applies to the second connector.
                  So I am looking for a blown fuse/component that is connected to the second pin on each power connector? Since the resistance is infinity on those.
                  I did not upload the second connector photos since they are exactly the same.
                  • CroTech
                    Student
                    • Dec 2012
                    • 149
                    • Croatia
                    #69
                    SO for the fuses, the only 2 I found are those by the HDMI connector and they are probably there for protecting the HDMI device, they checked out fine on the multimeter, in diode mode it beeps, in resistance mode they are short.
                      master hoarder
                      • May 2008
                      • 12175
                      #70
                      Yup, that's a pretty high resistance. That means you *don't* have shorted MOSFETs.
                      The middle 12V pin (and sometimes also middle ground on certain video cards) is used to tell the video card that the 6/8 pin PCI-E power connector is connected. That pin (or those pins) goes to a different circuit - hence the different (infinite) resistance. This is normal.
                      Yes, those are most likely to protect the HDMI device and also the video card, in case the HDMI cable or connector gets damaged.
                      That said, have you tried testing the video card on a different output connector, like the DVI-D or DisplayPort (if the card has one)?
                      • CroTech
                        Student
                        • Dec 2012
                        • 149
                        • Croatia
                        #71
                        Yeah. Tried both DVIs and the HDMI. Dont have a display port device so... But the card is not shown in the device manager. Are there any more fuses on the card I should check? Thanks for the reply Momaka.
                          master hoarder
                          • May 2008
                          • 12175
                          #72
                          It's not going to be a fuse issue. Check the GPU V_core and memory voltage outputs with the card/PC turned On. If they are normal, you probably have a BGA/substrate issue. These cards fail all the time like this. A reflow is probably in order (but I *don't* recommend an oven reflow, though).
                          • CroTech
                            Student
                            • Dec 2012
                            • 149
                            • Croatia
                            #73
                            I have to check where should I measure those voltages since I havent done this before but I will have it a go. I really doubt it is a BGA problem since the card worked flawlesly in my main rig but I upgraded to gtx 1070. My main fault was putting a molex converter to 6 pin since the old PSU had only 1 6pin power connector and even on first boot GPU was working fine but when I streesed the gpu with a game then it died.
                            • CroTech
                              Student
                              • Dec 2012
                              • 149
                              • Croatia
                              #74
                              Back with more info.
                              Found out that you can measure Vcore on the middle SMD capacitor on the back of the gpu, while PC was on, and everything connected I got 0.02V so that is saying the core is not getting the voltage.
                              Also started looking the VRMs, I have 4983NF
                              Tried this method
                              Diode mode beeps on DRAIN TO SOURCE no matter which probe is on which, also tried discharging the gate to ground, also beeps, and that is on every MOSFET
                              • CroTech
                                Student
                                • Dec 2012
                                • 149
                                • Croatia
                                #75
                                UPDATE:
                                Took one IC off a board and tested it and it checks out fine.
                                Checked for shorts on the PCB where the pads where, YUP all three SOURCE short to DRAIN.
                                Sorry for low quality photo.
                                Could it be that if one of the VRMs is making a short between SOURCE and DRAIN that they all get shorted?
                                I wonder what would happen if I took them all down.
                                • CroTech
                                  Student
                                  • Dec 2012
                                  • 149
                                  • Croatia
                                  #76
                                  Aaaaaand removed all of them, SOURCE AND DRAIN still shorted...
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #77
                                    The GPU chip died when the mosfets shorted. Sorry.
                                    A working TV? How boring!
                                    • CroTech
                                      Student
                                      • Dec 2012
                                      • 149
                                      • Croatia
                                      #78
                                      Yeah thought so,
                                      when watched this video
                                      • aaronkatrini
                                        DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                        by aaronkatrini
                                        I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                        - Put the card in my testing motherboard and start running Heaven benchmark
                                        - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                        - Try to start it again and I get a slight move from the PSU fan - a clear short
                                        - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                        - Put the...
                                        05-18-2025, 04:18 PM
                                      • jm942
                                        Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                        by jm942
                                        My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                        I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                        I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                        I did voltage injection on the cpu with 0.7V and i have a current...
                                        07-11-2024, 05:11 AM
                                      • joshAU
                                        Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                        by joshAU
                                        Hi all.
                                        This notebook was showing no signs of life.
                                        I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                        However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                        If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                        I tried replacing the MOSFET with a new one, but again no voltage on the...
                                        05-29-2024, 12:33 AM
                                      • dqtech
                                        Asus X455L Short Mosfet
                                        by dqtech
                                        I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                                        and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                                        08-09-2022, 08:53 PM
                                      • Jane
                                        How do you test MOSFET in laptops ?
                                        by Jane
                                        I tried to use this method:
                                        Testing an N-channel MOSFET:
                                        Step 1: Discharge the Gate (turn off the MOSFET)
                                        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                        Step 2: Charge the Gate (turn on the MOSFET)
                                        Now, place the red probe on the Gate (G) and the black probe on the
                                        09-27-2024, 03:31 AM
