PCH or SIO Dead? Maximus VIII HERO
  • baticzek
    • Mar 2024
    • Poland
    Hi yall (sorry for my english)
    I got an Asus Maximus VIII hero board that didnt start and react to power button at all. cmos and bios resseting didnt help so I shorted the green atx_enable wire to ground inside the 24pin atx plug and the board startet but code 00 was displayed. After that magically the powerbutton started to work again, but now the board only gives Q-CODE 00. The CPU gets warm and all voltages seem okay. All fuses are good and crystals seem to work. The pch gets warm. I tried reprogramming the bios chip and resetting cmos etc, but it didnt help me. I have boardview for this board but now I dont know what to do. Without the bios chip the board powercycles every second so it seems to read the bios code but doesnt post. Code 00 is now the problem I dont know if its related to the powerbutton issue before.
    VTTDDR 0.6v is missing and not shorted when not powered. When I turn on the board (standby or normal) it gets shorted to gnd with 0ohmbyt only if powered i dont know why
    The SIO gives always the RMSRST# signal o 3.5v
    Caps on the PCH are directly shorted to GND but when standby is turned on the short is gone and and 3v and 1v appears on them.
    All voltages except VTTDDR are good and cpu is getting hot (works on oher board)
    NO status led are turning on (CPU DRAM LED etc)
    Does anyone know what I should do next? Its a nice board so I want to fix it.​
  • baticzek
    • Mar 2024
    • Poland
    All reset signals except PLTRST are ok. When I force apply 3V to PLTRST the red CPU_LED start to glow and hdd controller led blinks for 0.1sec but still code 00. I dont know why but with PLTRST force enabled the CPU_LED now works but still not detecting cpu. Why?
    • baticzek
      • Mar 2024
      • Poland
      Checked the board again. PLTRST CPURST AND H_PWRGD are missing. Removed SR75 that connects H_PWRGD with CPU and PCH. PCH side is shorted. I connected 3v and there was 1A current. PCH got hot but nothing was connexted except my 3v on H_PWRGD. So Im 99% sure PCH is dead and it also probably caused the poweron problems. Its resistance on core voltage is 0.3ohm when not turned on. I will replace PCH and board will probably work again.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • chikineider
        ROG MAXIMUS Z790 DARK HERO, I need a board view or schematic
        by chikineider
        ROG MAXIMUS Z790 DARK HERO, I need a board view or schematic. The device powers on but has no video and no errors.
        Thanks​
        06-17-2025, 12:16 PM
      • k370
        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
        by k370
        I have a NM-A321 board that is dead, with no power at all.
        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
        • +3VALW
        • +5VAUX
        • 1.2VSUS_PWRGD
        • 3VALW_PGD
        • 1.05VAUX_PWRGD
        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
        09-23-2024, 11:57 AM
      • Maxpower3
        Boardview Asus MAXIMUS VIII HERO 60MB0M90-MB0A15
        by Maxpower3
        Hello
        Search Boardview Asus MAXIMUS VIII HERO ALPHA rev: 1.0
        ref 596518 -00328 - MB0P50 - A03 0205
        1st look and test:
        Lots of missing components under PCH + Socket damaged and tracks ...
        Lights up, starts but no reaction
        initialization remains at code Q 00
        following :
        after inspection and replacement resitor and repair track
        I replace the 0 ohm resistor under PCH and add another 0 ohm. (look pics)
        NOW, motherboard start
        but missing I still think 2 caps under PCH....
        01-07-2022, 07:39 PM
      • corrize
        Nikon D5 – dead, power board issue ?
        by corrize
        Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
        When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
        I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
        Now, I try to understand how it works.
        There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
        04-03-2023, 09:13 AM
