ASRock B560 Pro4 doesn't start
  • johnnys25s
    • 18
    Hy there.
    I have a ASRock b560 Pro4 MoBo that doesn't power up anymore after CPU swap. I used (my) CPU to test another (broken) board and after put it back, my board doesn't start. I've tested that CPU again but it's ok. I even bought another one for testing. I also have 2 PSU for tests. NO bent pins and no mechanical damage.
    I have different voltages on the board (in some places) but it doesn't start, at all.
    I have the schematic but I don't know what to do exactly with it. I have some skills and I can measure things. I need help to try to repair it. Thank you.
  • PEMOME1998
    • Feb 2022
    • 17
    • peru
    Hello brother, were you able to solve your problem? You should first check the RTC jumper with 3.3v. Then see S_RTCRST# AND S_SRTCRST#. Then see if it has 5 and 3v Stand BY, check if it has an RSMRST AND SLP_S3 signal. I have the same board, which does not heat the processor, but I do not have a schematic. I would be very grateful if you could help me with the schematic please. Thank you very much in advance!
    • johnnys25s
      • 18
      Hy there.
      No, I did not solved my problem. I cannot find someone who can help me to take every step at the time.
      I cannot fully understand what are all those things you said: "Then see S_RTCRST# AND S_SRTCRST#. Then see if it has 5 and 3v Stand BY, check if it has an RSMRST AND SLP_S3 signal".
      I do have 3.3V on pwrbtn pin in stdby and on BIOS chip and on some pins (60 and 61) from the Super IO. I also have 1.8V on a coil and in some other places.
      You should understand that my board does not power up at all.
      I will happily share the schematic if you can take some time to help me. Thanks.
        • 31055
        look VERY closely around the heatsink mounting points incase the cpu swap damaged some tiny smd part
        • PEMOME1998
          • Feb 2022
          • 17
          • peru
          I would be happy to help you in any way I can. If you could please share the schematic with me so I can tell you which signals you should measure and check.
          • johnnys25s
            • 18
            Hy there.
            I already did. Multiple times. I cannot find anything wrong, not even a scratch.
            Thank you.
            • johnnys25s
              • 18
              Schematic for AsRock B560 Pro4...
              All I ask in return is the help necessary to try to fix my board.
              [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...pro4-schematic
              • PEMOME1998
                • Feb 2022
                • 17
                • peru
                Ready, I could download it. Now, to start, I already deduce that you have the Boardview viewer program. You have to measure on the PL50 3.3VSB_A coil. Then also measure the following pins of the Super IO: 101 (3.3v) and 64 (3.3v). Check that and answer me.
                • PEMOME1998
                  • Feb 2022
                  • 17
                  • peru
                  Friend, thank you very much for sharing the boardview. I will be waiting for your answers so I can help you.
                  • PEMOME1998
                    • Feb 2022
                    • 17
                    • peru
                    Thank you very much my friend, I was now able to repair my board!
                    • johnnys25s
                      • 18
                      I will do those measurements and I will give you the results. Tomorrow. Now I am at work. I will also have to thank you for trying to help me.
                      • PEMOME1998
                        • Feb 2022
                        • 17
                        • peru
                        Okay my friend, I will be waiting for your answers. Thank you very much also for your help!
                        • PEMOME1998
                          • Feb 2022
                          • 17
                          • peru
                          My problem was that the processor was not heating up. What I was missing was VCCIO voltage. Which is controlled by the RT3651E. Which was missing the ENABLE. The ENABLE came to a double transistor, which had to have voltage on its pin 2, to ground pins 5 and 6. And leave free voltage for ENABLE. There was voltage on pin 2, but the double mosfet was not doing its job. I replaced the double transistor and it was repaired.
                          • johnnys25s
                            • 18
                            I am very happy that you fixed your board. I didn't have the time to make those measurements but I will do it because I really want to fix my board too.
                            • johnnys25s
                              • 18
                              Hy there !
                              On PL50 I have 3.3V on both sides.
                              On pin 101 is 3.2V
                              On pin 64 is NO voltage present.
                              • PEMOME1998
                                • Feb 2022
                                • 17
                                • peru
                                Hey friend, you don't have voltage on pin 64 SLP_S3. Okay, now give me measurement details of coil PL53 (1.8VBS), PL1V2 (1.2V OR 1.8V), RTCRST# (2.5V OR 3.3V), SP2 (VCCRTC 3V OR 3.3V). You can search for these signs in the upper area by their respective name.
                                • PEMOME1998
                                  • Feb 2022
                                  • 17
                                  • peru
                                  ALSO GIVE ME MEASUREMENTS OF: 3VBS_DSW (3.3V), DPWROK (3.3V), PIN 116 OF THE SUPER IO (PCH POWER OK SIGNAL). FROM THE LISTING ABOVE, 1.8VSB IS POWER SUPPLY TO THE PCH IN STANDBY. PL1V2 IS ALSO POWER FOR THE PCH, BUT I AM NOT SURE IF IT IS IN STANDBY OR AFTER POWER ON. IF YOU DO NOT HAVE VOLTAGE IN PL1V2, JUMP THE GREEN AND BLACK WIRES FROM THE SOURCE AND MEASURE AGAIN IF PL1V2 APPEARS. IF IT STILL DOES NOT ACTIVATE, WE HAVE A PROBLEM THERE.
                                  • johnnys25s
                                    • 18
                                    Thank you very much for not forgetting me.
                                    I will make those measurements this weekend. I do not have time till then. I have to work. But I really really appreciate your effort ! God bless you!
                                    • johnnys25s
                                      • 18
                                      Hy there.
                                      On coil PL53 (1.8VBS) is 1.8V on pin 2 (up) and 2.03V on pin 1 (lower side).
                                      On PL1V2 I have 1.8V on both pins.
                                      On PS2 I have 3.37V on one side (pin) and nothing (no reading or zero) on the other one (my resistor or whatever, is a little in another position, like horizontal) - pin 1 is the same value as the pin 2 of the BC1 (low from it) and same as same as pin 1 of SC15 and SC16 (up from it).
                                      If RTCRST (I cannot find it) is one (left) pin from CLRMOS1 then is 3V.
                                      If RTCRST is one pin of the PWRBTN then is 3.3V
                                      • johnnys25s
                                        • 18
                                        Picture of the SP2...
