ASUS TUF B450M-PLUS-PRO GAMING USB Overcurrent Detected
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Hello, so I got this ASUS TUF B450M-PLUS-PRO GAMING come in the shop with an issue of USB Overcurrent Issue. I already disconnect the USB connector going to the front USB port, and Check all port in the back and all are working and no short is detected,. Maybe someone can guide me how this USB Overcurrent Works because I got to boards with the same issue
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    I can mod the BIOS to disable the USB over current detection so it will not shutdown after 15 seconds, but you can only use Windows as the operating system. With Linux you will still get the USB OC message and continously spamming your terminal with it.
    I have done this mod to an ASUS mobo that I own. I'm using the mobo daily for the past 2 years to help me test and repair graphics cards and I have no issue with the USB ports or any USB devices that I connect to it.
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      I already tried removing ESD Chip same issue, maybe this is the last option we can do, can you edit mine? I will read the back up
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Upload it to file.io, and paste the link here. I will get back to you.
        Removing ESD diodes don't really help. The same with checking the USB OC voltage sense resistor divider network. Mine are even still on point.
        I found this problem to be specific only on Asus mobos with PCH chip that is going very hot all the time. It somehow messes up the USB OC detector inside the chip.
        ​​​​​I don't know why they keep implementing this useless feature because it simply doesn't work at all, and there are already PTC fuses installed on board that can do the protection job much better.
        • McWhitePink
          • Apr 2023
          • 103
          there are resistors connected to the OC pin, you should check those resistor values or maybe if any of them is open.
          Last time I have this issue and found one resistor was off.
          Should be easy to fix if you have the boardview file.
          • ronelex
            • Oct 2016
            • 195
            • Philippines
            Problem Solved, just a Leak 5 pin IC causing the overcurrent to activate
            • ronelex
              • Oct 2016
              • 195
              • Philippines
              thanks for the idea I solved mine 1 of the OC measures below 3v which caused the problem, I solved the 2 units with the same IC Issue
              • ronelex
                • Oct 2016
                • 195
                • Philippines
                Mine is the 5 pin IC is leak which pull down the reading
                • DynaxSC
                  • Apr 2021
                  • 477
                  • Poland
                  Hi, I have also one MSI board with same issue. Could you explain more in detail what 5-pin IC you mean, and what in this OC pin, i.e on which device it is located, PCH, SIO, ... ?
                  • mon2
                    • Dec 2019
                    • 14735
                    Each usb port on a good design will feature a usb current limit load switch. These sot23-5 or sot23-6 parts act like solid state relays that pass through to the usb connector, VBUS pin the +5V. If the current draw by the usb device is higher than the usb load switch peak current, the switch will kill the vbus rail to this connector. A fault is reported to the usb host controller by a status pin. Often, the usb load switch dies in the process and needs to be replaced.
                      • 22151
                      Originally posted by juswasakalam
                      this is the bios i used after flash good no usb overcurrent but after booting windows then restart the issu is still there... can you do me a favor ?.. can you mod my bios so i can use it .. im only using windows btw.
                      All bios request must be posted in the BIOS & Schematic Requests! sub forum --> https://www.badcaps.net/forum/troubl...matic-requests
                      You can start a new thread and then post a link to it.
                      • McWhitePink
                        • Apr 2023
                        • 103
                        I still believe there is a hardware failure on your mobo. shouldn't be the bios issue
                        • Fernon@Repair
                          • Jan 2021
                          • 34
                          • Sri Lanka
                          what is the 5 pin ic
                          • Fernon@Repair
                            • Jan 2021
                            • 34
                            • Sri Lanka
                            i have a same problem and same motherboard .... i all ready remove all esd protectors and reprogram bios . still not solve this problem what is the solution?
                            • Fernon@Repair
                              • Jan 2021
                              • 34
                              • Sri Lanka
                              what is the ic brother .... can you show boadview
                              • Fernon@Repair
                                • Jan 2021
                                • 34
                                • Sri Lanka
                                Hello I Have a same problem ..... but my this usb ports not working . usb 5v are ok I already removed esd all protectors in my motherboard and reprogram bios but still comming usb over current detected message and this 2 usb ports are notworking ...anyone have solution
                                • Fernon
                                  • Apr 2019
                                  • 20
                                  • Sri Lanka
                                  Bro you have mod bios ?
                                  • прямо
                                    • Sep 2022
                                    • 261
                                    • Indonesia
                                    Just so people don't keep sending me a chat message about disabling the USB over current auto shutdown.
                                    The ZIP contain the modded BIOS CAP files for PRO and PLUS, latest version 4622. They have been verified to work by user Fernon
                                    MOD EDIT .Link to bios -> https://www.badcaps.net/forum/troubl...nt-modded-bios
                                    • ronelex
                                      • Oct 2016
                                      • 195
                                      • Philippines
                                      this is the 5 pins IC of the board ASUS PRIME A320M-K which I used to replace the 5 pins of the 2 gaming boards I have repaired with USB Overcurrent Issue
                                        ASUS TUF Gaming FX506HF-HN028-GAMING Notebook F15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX506HF-HN028-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HF-HN028-GAMING boardview and FX506HF-HN028-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-07-2024, 06:38 AM
                                        ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook A15 Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FA506IU-HN153T-Gaming boardview and FA506IU-HN153T-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 11:20 PM
                                        ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 09:01 AM
                                        ASUS TUF Gaming FX505GM-AL323-GAMING Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX505GM-AL323-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505GM-AL323-GAMING boardview and FX505GM-AL323-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        ASUS TUF Gaming FX504GM-71250-GAMING Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS TUF Gaming FX504GM-71250-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GM-71250-GAMING boardview and FX504GM-71250-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 07:21 AM
