Asus H110M-K NOT TURN ON
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hello
    An Asus H110M-K motherboard is turned off. There is no connection on the motherboard, but there is no dual five volts on the motherboard, and when I manually connect the MOSFET PQ605, five volts are established, but it does not turn on, but as soon as the CLRS two-pin connector is connected, the system turns on and displays and it works without problems.Thank you for your guidance
ID:	3182299 Click image for larger version
  • stormanimal83
    • May 2014
    • 74
    Check for shorts on mosfet and on driver mosfet.... the board is not willing to turn on... if u do it by hand the protection is not active.... what ahppened to the slot? did u exchange the power regulator? right part number.??... next time u should do it by applying heat from bottom.... so u are not mnelting any other compnents... in my oppinion this board is ready for trash... they are not expensive.... no dual channel anymore perhaps...
    • khelane
      • Apr 2015
      • 172
      • xxxx
      The MOSFET is not short circuited.
      The resistance of the inductors is suitable and only the resistance of the inductor is 1.02 volts pch 36 ohms, the rest have good resistance.
      There is no problem with the slot because when the device is started and turned on, it shows images with RAM on both slots.
      The only thing I noticed is that when the motherboard is completely off for two or three hours, it means that there is no standby voltage. When the power is connected, it starts without any problems, but as soon as the power is cut off and turned on again (turning the power off and on for 30-40 seconds), the system does not start, and I turn off the power again, the system starts again for a few hours. And gives a picture!
      I don't have the schematic of this device, but I looked for the base of the MOSFET gate, it goes inside some low-range coach transistors.
      The motherboard has no financial value, it is only for experience and learning
      Thankful​
      • ductranvinh
        • Dec 2021
        • 135
        • Republic of Vietnam
        i think problem begin frome SIO and quartz. I'm not sure voltage supply for pch work 1.02 is ok,usally repair this model the voltage supply for pch work around 1.05-1.06 some times pch was damage can work at 1.1v
        [MOD EDIT] Link to boardview -> https://www.badcaps.net/forum/troubl...w-repair-guide
        PC work for schemaltic:
        Mainboard: Gigabyte Z68XP-UD4
        CPU: I3-3240
        Ram: 16Gb
        Graphic Card: GTX 1050Ti zotac 4Gb Mini
        SSD: 120Gb
        HDD: 2Tb
        • Roman555
          • Jul 2023
          • 20
          • Ukraine
          Hi. There's the repair guide for a similar asus motherboard. Try troubleshooting it step by step using the power flow and the power on sequence diagrams.
          Good luck!
          https://www.badcaps.net/forum/troubl...-guide?t=96586
          • khelane
            • Apr 2015
            • 172
            • xxxx
            When the motherboard is off for several hours. The device starts and enters Windows.
            I also showed you the PCH voltage in the picture.
            The system sometimes doesn't switch and I don't have 5 vduals. The MOSFETs have been tested and are healthy. And 5vdual itself has a high ohm.
            Sound card test. network card . RAM test. Hard.Graphic....done, the motherboard works without any problems when it is turned on!
            The main problem of this motherboard is that when it is not switched, the voltage is not 5VDUAL. And when this voltage is not there, I did an ohm check test, there is no connection and no low ohms!
            • DynaxSC
              • Apr 2021
              • 475
              • Poland
              Maybe some bad solder point depending on thermal conditions: warm does not start, cold does. Could be anywhere, chipset contact to mobo pads, some smd device, etc. You can try some mechanical pressure, or freezing spray. Could also be the chipset itself, its an old board, so chipset could be at the end-of-life. Chipsets relatively often fail on mobos, they are complicated devices, get quite warm, and can fail in a plenty of ways, also partially.
              1.02V for chipset is also slightly too less, should be 1.05V. Some voltage setting precision resistor in the 1.05V VRM might be decalibrated.
              Check the resistance of the 1,05V power line, should be some 20-70 ohms, if lower than 20 ohms might be a sign that chipset is going to fail.
              Working chipset silicon temp. w/o heatsink should be some 55 C., if much higher also a sign of failing.
              • Roman555
                • Jul 2023
                • 20
                • Ukraine
                It doesn't matter there is 5vduals or not. 5vduals is controlled by SIO that looks start conditions. Find in the repair guide section #3 "POWER ON SEQUENCE" and check all steps from 1 till 9. I mean to measure signals that are figured in these steps. Also a motherboard won't turn on if 32kHz crystal doesn't work.
                • ductranvinh
                  • Dec 2021
                  • 135
                  Oh my JESUS! 5vsdual was transfer from 5v after psu work! Big problem if you want star the mainboard working. You need RSMRST (Signal - 3.3v) and Quartz (SX1). Maybe you want repair this problem,you replace new sio and quartz!
                  CPU: I3-3240
                  Ram: 16Gb
                  SSD: 120Gb
                  HDD: 2Tb
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • Scotchmist
                    Asus GA502D keeps blowing mosfet
                    by Scotchmist
                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                    I have removed the mosfet and can run the laptop no problem
                    The MOSFET is FDPC5018SG
                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                    08-24-2024, 02:23 PM
                  • MicroSMD Lab
                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                    by MicroSMD Lab
                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
                  • someonenotyou
                    ASUS G513R - cannot remove MOSFET
                    by someonenotyou
                    Hi.
                    I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                    I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                    Of course, I did not force it, but tried to lift it up with tweezers.
                    Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                    10-10-2025, 11:05 AM
                  • Timp74
                    Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                    by Timp74
                    Hi All,
                    Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                    I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                    08-13-2021, 01:11 PM
