AIO C460 BIG FONT PROBLEM(6050a2602301.a01)
  • SR IT SOLUTION
    • Jan 2023
    • 61
    • INDIA
    hi all ,
    i have AIO Lenovo c460 .the problem is
    The size of my screen font is very large and it remains visible even after opening the window or in the BIOS setting. I tried changing the main screen,
    i program bios also but the problem still same, any one help??
    • 21293
    Originally posted by SR IT SOLUTION
    hi all ,
    Schematic ? - https://www.badcaps.net/forum/troubl...io-c460-b40-30
    Does your board have the TSUMU88MDT3 scalar chips .
    • SR IT SOLUTION
      • Jan 2023
      • 61
      • INDIA
      no chip found
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
