MSI 6309, 470uF capacitor location???
  • supersabre
    • Feb 2006
    • 45
    Hi, i am in the process of recapping MSI 6309 ver2.1 mobo. The board have whole bunch of bad cap.
    I removed all of the 1000uf and 470 uf cap. THere are 3 caps with 470uf and 6 caps with 1000uf.
    however, i can't remeber the location of one of the 470 uF. I remember there are 1 for front and 1 for rear usb. And there are still one 470uF left.
    I know all versions of 6309 are similar in term of cap layout.
    If anyone know where the 470uf is located on the board, please let me know.
    Thanks!
  • gdement
    • Jan 2007
    • 690
    Re: MSI 6309, 470uF capacitor location???
    c26 (next to the kb connector)
    c110 (just below the ide ports)
    ec14 (between pci slots 3/4)
    This board is marked "VER: 2"
    • supersabre
      • Feb 2006
      • 45
      Thanks a lot!
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
      • Junkrepair
        Calculating ESR from tan delta -- tan delta's dependence on capacitance
        by Junkrepair
        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
        I found this nice little description of the conversion:
        Calculating capacitor ESR from Tan(delta)
        https://forum.digikey.com/t/calculat...-from-tan/2633
        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
        06-12-2023, 02:45 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
