Eupa/PC Chips Model 'IBB' - Bad Caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    This is one of those goofy off-brands AKA PC Chips... They're a real whore to identify sometimes... Anyway, one crossed my path, and there's no doubt what's wrong with it... The caps are branded 'Lelon', which is a familiar face in the bad capacitor realm... :roll: :evil:
    After recapping, working like a champ... The owner had a P3 1.13GHz Tualatin CPU with a Slotket... Talk about squeezing every last booger outta this baby! I have to admit, I booted it up on Knoppix, and it was a really snappy and stable board! Gotta love new caps!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • MD Willington
    • Sep 2004
    • 702
    What brand caps did you use on it?
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      those rubycon MBZ or MCZ they so pretty.
      you know the little chhsi caps which you left, they look like they are doing a bulge at 4 places between the vents. i see that a lot with the little caps. are they like that because they are failing a bit or is that what they always look like cos the vents are pushed down when they make them?
      i have some boards with rubycon for the major caps but all the little caps look like that. prolly not worth recapping right?
      • MD Willington
        • Sep 2004
        • 702
        They're sexzee!
        MD
        • piernov
          NVidia bumpgate
          by piernov
          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
          May complete this post at a later date with more details.
          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
          03-27-2021, 10:34 AM
          by momaka
          03-12-2025, 03:42 PM
        • ugamazing
          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
          by ugamazing
          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
          08-31-2022, 07:34 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
