EPOX 8RDA+ rev1.1 with BAD CAPS
  • noorman
    • Jul 2004
    • 10
    After just under a year's use of this board, I found a bad cap on it during a visual check; I 'd just read (not for the first time) about these and since I had a few rare occurences in the days before ...
    I found one bad Cap among the lot (so far); on my board I found a MIX of cap makers - SANYO (good) and GSC (bad).
    About 'GSC' I 've read a lot of bad things on another forum / many owners reporting bad caps from this maker !!!
    I 'm looking for GOOD replacement caps to do the replacement myself:
    GOOD are Sanyo, Panasonic, Rubycon, Chemi-con, EPCOS (Siemens before).
    Sanyo you need to look for EXR Hybrid series
    Rubycon you need MCZ (or MBZ) series
    EPCOS you need B41859 or B41886 series
    Chemi-con you need KZE, KZG, KZH series
    Panasonic you need FM or FC series (EEU-FM = 105°C /7000h)
  • PremiumWood
    • Jul 2005
    • 5
    Re: EPOX 8RDA+ rev1.1 with BAD CAPS
    thanks! i was looking for a list of the capacitor models/brands i need for my boards. useful info, good post thanks
    • cj_reha
      Mystery 80s Sanyo cap - perhaps polymer?
      by cj_reha
      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
      01-06-2023, 09:24 AM
    • Wet_Cap
      EPCOS Cap Replacement
      by Wet_Cap
      Hey everyone. Just wondering if anyone can help me with some capacitors that blew on a VFD. Caps are EPCOS B43501-S3277-M1, 270uF, 385V, three pin. Markings on capacitors are as follows.
      EPCOS
      B43501-S3277-M1
      270uF (M)
      385V 40/085/56
      10.10 S3
      Tried looking on Epcos website which takes me to TDK. Tried searching with no luck for specs on cap. I just want to find all the information I need to replace these caps. Any help greatly appreciated.
      08-28-2022, 12:00 AM
    • kotel studios
      Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
      by kotel studios
      Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
      Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
      So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
      What I've tried so far:
      replace the original N-MOSFETs with beefier 60V ones for testing
      Resolder the resistors near the Vcore Jumper block
      Short Vcore...
      05-25-2025, 01:46 AM
    • toddw65
      Sanyo DP5834 - Gray Screen
      by toddw65
      Hey All,
      I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
      Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
      Thanks,...
      10-31-2024, 10:37 AM
    • hugocarmo
      Sanyo VHR-D4710G VCR no sound.
      by hugocarmo
      Hi again guys.
      Today I have a problem with this Sanyo VCR.
      I bought it online, It worked sometimes.
      I recap the Power supply and it started working fine.
      Image is perfect and all digital effects too.
      All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
      I have no sound on playback, on tuner, or aux in.
      On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
      On one of the sound processing...
      01-23-2024, 12:58 PM
