How to remove busted legs off caps still stuck in vp6 mobo??
  • Road Warrior
    • Jul 2004
    Desoldered caps on a vp6 but most of the negative legs
    completly snapped off inside the holes
    Anyone know how to get rid of those things still stuck in the holes
    with no meat on them?
    Road Warrior
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    That can be a little tricky sometimes. There are a couple easy ways of doing it...
    1) If there;s a little bit of leg still coming through (enough to get a bite on with small pliers or side cutters), simply heat the lead on the back of the mobo and lightly pull it through the top of the mobo with the pliers.
    2) If the leg is broken off flush with the board, melt the solder and use the dental pick to push it through the board. That's a sure-fire way to get it out.
    3) Use a solder sucker. I don't recommend this unless you have a professional-grade vacuum type. Mechanical solder suckers can damage the board when they recoil.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Road Warrior
      • Jul 2004
      Thanks for the advice Topcat
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • eastcoastcomputing
        Macbook Air A2179 - Mobo 820-01958 stuck at 15.2V
        by eastcoastcomputing
        Hi there,
        I've got this case that puzzles me and I couldn't find any similar case to explain it. Maybe you guys can help?
        The computer went to black screen while being used and fan started to rev full speed. It had to be forced shut down. Since then, fires up but no display, no chime and not in DFU.
        I took the board out and inspected it with microscope: no visible damage to chips, no liquid damage. I checked all coils: no short.
        The board goes to 3.5V, then 5V, then gets stuck at 15.2V.
        L7030, L7400 and CPU (with its cooler on)...
        07-23-2024, 03:31 AM
      • woody-009
        Tips on how to remove a very stuck memory chip on a GPU?
        by woody-009
        Hi Everyone
        I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
        So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the...
        05-10-2022, 02:54 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • stormanimal83
        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
        by stormanimal83
        Hey....
        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
        01-18-2024, 02:15 PM
