Re: EP 61BXA-M sucess story, but... [Fix complete!!!Pictures inside!!!]
Rainbow thanks for your feedback!
The specs of the CET CEB6030L (Logic Level) MOSFETyou gave me on your previous post:
" Rds(on)=20mohm @ Vgs=4.5V, Id = 52A continuous, 156A pulsed,"
were most helpful!
Also, the info that:
" Yes, you can use logic level mosfets for all motherboard VRMs"
was the definitve info I was looking for!
After I've read your reply I understood that if I wanted a MOSFET that won't overheat at Id("nominal-for-P3@600MHz-usage") = 20A (or more) I have to:
1 - get a Logic Level MOSFET;
2 - get one with at least Id(continuous) >=50A (or something like that), but NOT Id(max)=26A (like the BUK455-100A
I've Googled a little bit for CET CEB6030L datasheet, found it, and study its characteristics.
Then I delved on my "dead-mobo-trash" and I found 2 x Fairchild FDB6030L (Logic Level MOSFET) on a dead Socket370 (Pentium 3 mobo). I thought that If these MOSFET's are on a P3 mobo then I assume that those specs were those I was looking for
... presumably similar to those you gave me on your previous post.
Again, I've Googled a little bit for Fairchild FDB6030L datasheet, found it, and study its characteristics. The Fairchild FDB6030L specs are similar to those you advice me to. Its specs are:
48 A, 30 V ;
RDS(ON) = 13 mW @ VGS=10V ;
RDS(ON) = 17 mW @ VGS=4.5V ;
Critical DC electrical parameters specified at elevated temperature ;
High performance trench technology for extremely low RDS(ON) ;
175°C maximum junction temperature rating ;
so I've unsoldered these 2 x Fairchild FDB6030L, and tested them for eventual malfunctions (http://www.uoguelph.ca/~antoon/gadgets/mostest.htm. The 2 x Fairchild FDB6030L both passed the tests, so I though that I could give them a try!
Near the Fairchild FDB6030L datasheet ( http://www.fairchildsemi.com/pf/FD/FDB6030L.html ), on the Fairchild site, were some app notes for Katmai VRM...what a luck! Precisely what I'm looking for.
I recalled what gonzo0815 had said something like: "look for schematics of the VRM on the driver chip datasheets".
I browsed that PDF (, and voiláthe info I was looking for -- these Logic Level MOSFET were for 12V input --, precisely what I was looking for this mobo!
After some solder work, I've replaced the Philips-BUK455-100A (not-Logic-Level-MOSFET) for this Fairchild FDB6030L (Logic-Level-MOSFET).
Now, I've replaced only the BUK455-100A MOSFET. I've kept the (2nd) original MOSFET --the one that does not overheat. I know that you adviced me to replace the 2 MOSFET's on the mobo for 2 identical Logic-Level-MOSFETs, but since only one of them was "problematic, i.e., overheating" I assumed that I could keep the "not problematic, i.e., not-overheating" one. This one is still one of the originals, never replaced MOSFET.
After I replaced the MOSFET I've switched the power on and it worked! Then, I ran Prime 95 torture test and after the 1024K pass, the temperatures were about 43ºC on both MOSFETs @ room temperature = 17.1ºC If the room temperature raises to 37ºC (+20ºC that the current room temperature) I assume that both MOSFET will go up to 63~65ºC, under heavy load (Prime95), so I guess that this is normal, and I should not worry! Please, care to advise me IF I should worry about those temperatures under load!
Since both MOSFETs have the same temperature under load, running P95 on a P3@600MHz, THEN I assume that the original MOSFET -- the D50N03A --, is also a Logic Level MOSFET (Correct me IF this assumption is somehow wrong!), maybe with 50A, 30V, like kc8adu had mentioned on a earlier post, but since he had not documented it's words, I don't know for sure some other relvant characteristics, like Rds(on), etc. But I'll assume that they are slighty "worst" than those of the Fairchild FDB6030L , since P2(Klamamth/Deschutes) current requirements are slightly lower than Katmai (P3) current requirements.
The 2 x TAYEH 10v 1000uF Caps were also replaced for 2 x VIVA 10v 2200uF, found on a PSU. I don't know their ESR values, but since it's temperatures don't go above 45ºC under P95 @ room temperature = 17.1 ºC, I'll assume that maybe if it goes as high as 65ºC (@ room temperature = 17.1 ºC) I should not worry. Maybe some low ESR could help me a bit, but, hey, it's old material, if it's working with 0€ spent, why bother?
Well, this post is really long, but I hope it will help and encourage some other persons to carry on when they lost their hope. To finalize, here is the picture of the 2 x 10v 2200uF caps (tall, black caps, at the left), and the Fairchild FDB6030L Logis Level MOSFET (the MOSFET that is most on the left on the "2 x MOSFET cluster")
Again, Thank You All that feedback me!
Kind regards,
Mikeluz
were most helpful!
48 A, 30 V ;
Kind regards,
Mikeluz
