Small TK caps on MSI P31 Neo V2 aka MS-7392
  • a-nika
    • Jun 2013
    • 10
    Hello All,
    I got a four year old P31 Neo V2 equipped with TK, Ost, G-Luxon and one Teapo. By now 16 out of 19 of the small TK ATWY 1000uF 6,3V TK caps have bulged.
    The problem is, I cant manage to find any datasheet mentioning these. This one is all I found. But, the caps MSI used here are 8mm in diameter and I would guess 11,5mm high. What would you suggest to use as replacement?
    I guess it would be wise to change the other TKs aswell. They are in primary CPU VRM and primary aswell for RAM, I think. What would you do with the shiny cyan Ost near the CPU and the 8mm G-Luxons for USB 5V?
    I wonder if it will be worth it, probably not if I had to change just every singe cap on that board. The PC is on light, only private use and decently cooled. So these TKs really could not stand anything. Who knows they would have gone awry if stored in a warehouse, aswell.
    Here is the complete List for MS-7392 Ver. 1.2
    19x - TK ATWY 1000uF 6,3V 8mm/11,5mm - everywhere
    7x - TK ATWB 1000uF 16V 8mm/20mm - VRM
    11x - Ost RLA 680uF 4V 8mm/9mm - CPU VRM sec.
    4x - G-Luxon LU? 470uF 10V 8mm/11,5 or 12mm - USB
    1x - Teapo SZ 470uF 16V 8mm/11mm - near PCIe 16x
    1x - Ost RLG 470uF 10V 6,3mm/11mm - above Southbrigde
    Any ideas, suggestions and datasheets are very welcome.
    Cheers, A.
  • mariushm
    • May 2011
    • 3799
    Re: Small TK caps on MSI P31 Neo V2 aka MS-7392
    ftp://helpedia.com/pub/temp/datashee...in%20Kogyo%5D/
    for TK Toshin Kogyo
    You'll find the others on that ftp as well.
    Sigh, that ftp's a mess. I guess I should move my ass and clean it up.
    • a-nika
      • Jun 2013
      • 10
      Wow, that was fast. Thank you for the datasheet, mariushm.
      As it turns out the bulged ATWB are 25mΩ and handle 1300mA ripple. What would be more important to match, impedance or ripple?
      Oh dear, I can only find Nichicon HM 820uF with 30mΩ and 1140mA at farnell.
      Are those specs made up by TK? I cant believe that this is for real.
      Cheers, A.
      • a-nika
        • Jun 2013
        • 10
        Wait a moment, I clicked the wrong datasheet. The ATWY series doesnt feature 1000µ 6,3V 8mm. Thats only in ATWB.
        Huh, thats strange.
        • mariushm
          • May 2011
          • 3799
          Use capacitors rated for 10v or 16v where you can, instead of 6.3v. Bigger can size, better specs.
          A few mOhms extra won't make much difference and i do believe those were somewhat optimistic values listed in TKs datasheets.
          • kevin!
            recapping PCB.
            • Jul 2013
            • 195
            • España
            I would advise changing those capacitors CPU VRM (those blue OST), for a solid. are bad, I had a MSI 661FM3-V and is swelled several of these capacitors causing failure.
            A photo of a several swollen ...
            Gaming pc:
            nVidia RTX 3080 TI, Corsair RM750I.
            Workshop PC:
            Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
            Server:
            • RJARRRPCGP
              • Jul 2004
              • 6304
              The TK caps on my Acer Aspire M5630 are doing fine. :/
              Could it be related to board design?
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • kevin!
                recapping PCB.
                • Jul 2013
                • 195
                • España
                Can be,
                Some time ago two plates pull a packard bell MSI (is also in hp / acer / PB) TK swollen capacitors. I think they put capacitors unsuitable for faster spoilage.
                I found that the line PSU to have capacitors 10v in line 12v ...
                Gaming pc:
                Workshop PC:
                Server:
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  No. TK are just plain straight unreliable. There are many recorded failures here on BCN forums.
                  Maybe you just got a somewhat decent batch from them.
                  Or maybe they aren't under that much stress in your system.
                  Or maybe they are bad/starting to fail but just not showing it. If your motherboard uses a good design, perhaps it's just capable of working even with some of them going bad. But that's never a good thing.
                  In any case, if the motherboard is of any value to you, then you should recap it.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    The only good thing about TK caps? They fail which means I got a free "broken" motherboard Is it true that some are based out of Japan and some are based out of Taiwan?
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      It may be true. I have TKs on an Acer Aspire M5630 and no signs of them failing.
                      Arc A770 16 GB
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I think TK's head office is in Japan, but their factories are in either Taiwan or China.
                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:44 PM
                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 03:36 PM
                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                          This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                          09-12-2024, 03:28 PM
                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
