msi 6382 v1
  • Sylvester
    • Nov 2006
    • 67
    msi 6382 v1
    This is an oem board, got 1 that has all G Luxon 1500uF caps blown, 3 x 10v and 6 x 6.3v. Never noticed until posting that the board had 3 x 10v caps, ordered 6.3's Its got 3 x 4700uF 6.3v HD nichicon alu cans which look fine. Between pci slots 1 & 2 a sanyo 1000uf 6.3v and 3 Chhsi 1000uF 6.3v, the sanyo is lower in height than the others. Its a project board so if it doesn't work, nothing lost, just a bit annoyed not noticing the 3 10v's. I'll post a photo of the board if there's interest.
  • Shroomie
    • Apr 2006
    • 356
    Re: msi 6382 v1
    6.3v caps of better quality would be fine. There's only three positive voltages going through a board: 3.3v, 5v, and 12v. MSI wouldn't have used 10v caps on a 12v line; the higher rating of the caps is to make up for their lower quality. They'll be on the 5v, so you'll be fine with your 6.3s.
    The Nichicons are almost certainly fine, I believe the Sanyo is as well. Might be a good idea to replace the Chhsis too, they're certainly not good caps, worse than G-Luxon even. If you don't, just keep an eye on them.
    Good luck! I'm sure someone'll come by with specifics if I missed anything.
    You know there's something wrong when you open up a PSU and are glad to find Teapos.
    Why I don't buy cheap cases!
    • Sylvester
      • Nov 2006
      • 67
      Re: msi 6382 v1
      Just a quick update, I've replaced the 6 G Luxon 6.3v 1500uF caps and 3 Lelon 10v 1500uF caps, the board seems to be fine so far. As this was a project the caps used were yageo 6.3v 1500uF. 7 of the 9 caps were in a bad way. I haven't bothered with the 11 or so Chhsi 1000uF 6.3v caps as yet. Needed the 50w iron to do the job, and clearing those holes!
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • ssl6
        MSI K7T266 Pro (Ver. 1.0)
        by ssl6
        Hey Everyone,
        Long time lurker, but I think this is my first time posting.
        Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
        I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
        11-09-2023, 01:00 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
