Shuttle SB61G2, shorted NB? && Cap Replacement Question
  • Sudos
    • Dec 2012
    • 17
    I have a 10 year-old Shuttle SB61G2 here that I seem to have stupidly killed.
    I was testing different ways of mounting LED strip lighting inside for some illumination, but ended up letting the tip droop down and touch a resistor in between the RAM slot and the capacitor on the bottom middle of the board shot below. for reference, that's the capacitor with R233 marked by it, not for it, but just to be clear about location. The area it touched is in the vicinty of the 4 resistors there. They all test out fine, so I powered it up.
    Note: the motherboard model is FB61, v2.1.
    Plugging it in, I get a noticeable whine from he coil to the right of the southbridge (heatsink'd) above the two Mosfets. Both of those also check out fine. Also noticing the northbridge getting unusually hot while off with just the power plugged in. you can see where I put my bare finger to the core to confirm this. the machine turns on from this point (heatsink back on), but does not POST. fan spins. the LED next to the fan connector to the right does not turn on.
    My stupidity is the weakness here, letting the end of the LED strip touch the resistors in the first place and effectively either putting ground or +12v to them directly. I'm not sure what one it touched in that small area and what it could have fried, but my worst nightmare would be the 865 NB. a new one will cost me a kidney on eBay, something I'm willing to do, but I want to see if it's repairable or not. I can take more pictures if needed.
    Secondly, once I get this working again, I'm considering swapping most of the capacitors in important areas like the CPU and by the PCI/AGP slot with polymers, since these are all the original OST caps, not one bad, but aged well enough I'm going to take precautions. I have a Pentium 4 Extreme Edition 3.2 I want to drop in, but can't now, because of this little issue. if I replace the caps, which polymers should I shoot for?
    Other cards installed while the machine was on during the event were an HD3650 512M AGP card and an Audigy 2 ZS PCI card. the RAM is standard run of the mill Kingston KVR 2.5v DDR-400 in the total of 2GB.
    Picture of Motherbaord (10MB!)
    Picture of Motherbaord (smaller, 5.3MB)
  • mariushm
    • May 2011
    • 3799
    Re: Shuttle SB61G2, shorted NB? && Cap Replacement Question
    Maybe you just popped the resistor or some capacitor connected to that ground plane?
    Right by the capacitors you have a ground and a voltage trace... the large capacitor by the R233 seems to be connected to those large traces. There's also C104 at the end on the left.
    The whining may be an overloaded regulator or power supply, which could be a sign of a short. You may have put 12v on the ground while there was 5v or 3.3v on the other trace. That may have blown up some of those ceramic capacitors between the traces or some ceramic resistors, any of which might be now shorted.
    Check if there's continuity between those copper traces (put the probes on each side of R233 or on the sides of CD104... if there's full continuity, see what other values those resistors have and try to determine where the short is.
    / nice 10 meg picture, though a bit grainy
    • Sudos
      • Dec 2012
      • 17
      You can thank Sony for that. stupid camera doesn't even have a manual macro setting.
      R233 and CD104 as well as CD104 and a few other capacitors around all have a continuity of .005 with my cheapie Radiocrap meter. the ones marked CD56 and CD57 up by the NB and coil show a continuity of 0. so I'd think that those are blown then? there's also that little group of smaller ones and resistors as well under that, I checked a few there and was given quite a few different readouts from .075 to .901 on one of them. so I'm not even sure at this point.
      Also: Here's an image of the underside of the board. I upped the contrast slightly to better the details of the traces. you can see where they go from in that area straight into the northbridge, and that scared the ever-living crap out of me when I saw it.
      Motherboard Underside (10MB!) ...and it looks like my board picked up a straggler! little fuzzy stuck to the hole by ZCD23 has been removed!
      • mariushm
        • May 2011
        • 3799
        Yeah, well, it's obvious you have a short there. but 0.005 and 0 are too close together to be really sure.
        I'd recommend touching the probes together to eliminate the internal resistance of the probes, then using the REL mode if your meter has one, and try again.
        But unless you have a 6000 count or better meter, it might be too hard to determine where the resistance changes to a much bigger degree to indicate a dead short.
        Another option would be to take out resistors and capacitors one at a time and test each one separately until there's no more any short... it's doable but you have to be careful not to lose the resistors and capacitors.
        • Sudos
          • Dec 2012
          • 17
          no REL mode on this cheap meter, a real bummer.
          I'll take a look later on. for now, it's work time.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Put heat sink back on NB, remove all add-on cards, drives, and peripherals except for keyboard. Then check voltages on all important rails on the motherboard when it's turned ON and when it's OFF but still plugged in.
            Important rails:
            - CPU VCORE
            - Northbridge VCC (the coil above the Southbridge, should read about 1.5V for i865 chipsets)
            - RAM primary (about 2.5V to 2.6V)
            - RAM secondary (about 1.25V or 1.3V, I don't remember the exact spec for DDR)
            - AGP bus (if the motherboard has AGP - usually 1.5V or 0.8V for newer boards)
            That's about it. There are more rails, but they vary between different motherboards and generations.
            NB data sheet can be found here:
            By the way, how did you establish that the MOSFETs for the Northbridge VCC supply are fine? Reason I ask is because ceramic caps CD56 and CD57 filter the NB VCC in addition to the electrolytic caps, so if the lower MOSFET for the NB VCC is shorted, ceramic caps CD56 and CD57 will appear shorted too (as would the Northbridge). Also check the gate resistance of those MOSFETs to ground.
            When performing any voltage readings, I would say avoid powering the motherboard for any extended period of time.
            BTW, nice picture quality. Really REALLY helpful.
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • lolich112
              How to find out what resistors i need as a replacement?
              by lolich112
              Hey,
              I have a Palit GTX 750 StormX with 2 gigs. on the backside right above the pcie connectors there are multiple conponents (See in the pics). I suppose those are resistors or capacitors. 2 of them broke of and now I need 2 replacements. I looked arround for some schematics but couldn“t find any. Someone have an idea how to identify those?
              Thanks in advance!...
              09-03-2023, 01:37 PM
            • modtool
              HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
              by modtool
              Hi to all,
              the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
              I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
              I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
              04-01-2025, 08:22 AM
            • BalkanBoy
              Dead Razer Blade 14 2022, shorted CPU?
              by BalkanBoy
              today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
              Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
              I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
              Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
              I removed coil and injected 0.7V, it draw around...
              09-27-2024, 12:44 PM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
