GA8VM533-RZ V-core drop after POST
  • stng
    • Jul 2006
    • 34
    Gor myself a Gigabyte GA8VM533 RZ,after troubleshoot.found out
    one of the VRM mosfet shorted,the part no is FDD7030L ,i don't have
    a actual replacement part so i get a nearer substitude 60N03H
    and not sure is it becoz of not proper replacement part after i fired
    up it POST but freeze at POST screen..then i check the V-CORE
    and found out the V-CORE will drop from 1.75V to 0.08V ..
    guys any idea what's coz the V-CORE drop ? anything to do
    with bad cap ..have try change the cap but still same..
    INTEL CORE2DUO E6600 LGA775 + Cooler Master Hyper L3
    Asus P5W DH Deluxe (Wireless edition)
    2Gb Kingston DDR2 800
    Asus Xtreme N7600gs 256Mb Silencer PCI-E
    80Gb WD 7200 SATA + 40Gb Maxtor 7200 x 2 +
    80 Gb Seagate 3.5'' external HDD
    HL-DT-ST DVD rom GDR8163B
    HL-DT-ST DVD Ram GSA-4167B
    20'' Dell FPM LCD
    Cooler Master Centurion 5 + Acbel 450w with Active PFC
    Philips A2.610 5.1 speaker +
    Altec Lensing AHS30
  • gonzo0815
    • Feb 2006
    • 1600
    Re: GA8VM533-RZ V-core drop after POST
    probably another Fet is shorted, may be a cap is shorted too. Wich brands of caps are on this board?
    • davmax
      • Dec 2005
      • 899
      It is wise to change MOSETs in pairs. A short in one will damage the other. Also it is possible that the driver chip may be damaged. Can be a tough one.
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      Samsung 18x DVD writer
      33 way card reader
      Windows XP Pro SP3
      17" Benq FP737s LCD monitor
      • stng
        • Jul 2006
        • 34
        Can't continued further as suspacted one of the PWM chip that controlled the
        Mosfet spoiled ..
        20'' Dell FPM LCD
        Altec Lensing AHS30
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          06-24-2025, 07:34 AM
        • Francisco.s
          CPU vcore missing in HP workstation Z2 Mini 4G
          by Francisco.s
          Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
          The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
          It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
          Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
          The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
          I wonder which circuit generates this enable...
          04-22-2024, 12:35 PM
        • mikzs
          Rx580 8gb sapphire nitro+ turn off vcore randomly
          by mikzs
          Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
          11-06-2023, 12:28 PM
        • jm942
          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
          by jm942
          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
          I did voltage injection on the cpu with 0.7V and i have a current...
          07-11-2024, 05:11 AM
        • conghuyms
          MSI RX580 Vcore voltage is too high, please help me !!!
          by conghuyms
          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
          What should I do...
          08-02-2025, 11:38 PM
