Asus P8Z77 V
  • Philly Cheese Steak
    • Mar 2011
    • 114
    Asus P8Z77 V
    Hello all!
    I have this board Asus P8Z77 V, with a "no post" at first I thought it was a bent pin in the CPU socket. But when I looked the whole board over good, upon turning it over I found a chip missing off the back side. I assume its a resistor but because its gone I'm not sure?
    IF anyone could post a Detailed photo of the back side of a Z77 board between the CPU hold down plate and the first PCI-e Slot. Here is mine, sorry its so bad my camera does not like close ups. So I used a magnifying glass to help. If you need I can post better photos.........
    Thank you!
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
    • Mar 2011
    • 114
    Re: Asus P8Z77 V
    Here are some better photos, my camera needs up grading.....
    I assume its like the others in the same area, I could measure there resistance but don't want to guess...........................Or if you can post a resistance that you found on your Z77 board then I wouldnt need detailed photos and could move forward.
    Thank you!
    any help!!!!!!!!!!!!!!
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    SSD'S
    Corsair AX1200
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Re: Asus P8Z77 V
      Could be a ceramic capacitor perhaps?
      I can put text here?!
        • Mar 2011
        • 114
        Re: Asus P8Z77 V
        What is its value, perhaps?
        X99 5930K
        X99-gaming 9
        EVGA 1080 Vanilla
        SSD'S
        Corsair AX1200
          • Mar 2011
          • 114
          Re: Asus P8Z77 V
          Seriously man, go spam up some other post!
          So this isnt rocket science I know, so in this photo you see there is another resistor with the square around it, I used a multimeter on it to find its value .220 I think it was and here is my doner card a Nvidia GPU 6800 ultra DOA.
          X99 5930K
          X99-gaming 9
          EVGA 1080 Vanilla
          SSD'S
          Corsair AX1200
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Re: Asus P8Z77 V
            Looks like a ceramic cap to me as well. Not sure what value. If you really need to know the exact value, then you would need someone who has the same motherboard to take off that cap on theirs and measure it.
            The good news is, I've replaced broken caps like that before with success without knowing what value they were. I simply just put another ceramic capacitor of the same physical size. Your donor GeForce 6800 should be good for that. Just look for tan square components - those are usually the ceramic caps. If it's silver or black - beware! That would be a ferrite bead, a resistor, or a diode and could totally mess up your board.
              • Mar 2011
              • 114
              Re: Asus P8Z77 V
              Got ya!
              I used one the same size approximatly, still no boot. Gonna look it over some more..............
              Thank you!
              X99 5930K
              X99-gaming 9
              EVGA 1080 Vanilla
              SSD'S
              Corsair AX1200
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • DynaxSC
                ASUS STRIX Z490-F GAMING - No POST, stubborn board
                by DynaxSC
                I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                The situation looks like this:
                After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                1. RTC oscillates normally (32.768KHz).
                07-08-2022, 05:45 AM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • ShadowAi12
                ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                by ShadowAi12
                I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                • The board enters a "ready to power on" state after plugging in the PSU.
                • Pressing the power button increases power draw.
                • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                Measurements:
                (taken after pressing the power button, while the board is attempting to start)
                • H_SKTOOC#
                06-11-2025, 01:05 PM
