SciLabs GeForce 4 MX 440 with bad caps
  • Deathshrimp316
    • Jan 2006
    A few years ago I purchased a GeForce 4 and have been using it for quite a while with it overclocked, no problems. It had run fault free until I put it into my newest PC, where I believe that a hot motherboard (due to poor contact between the CPU and its heatsink - the CPU fan had to run at 5500+ rpm to keep it at 60 deg. C) contributed to the failure of 2 capacitors on my video card. At first they were slightly bulged and the card continued to run as per usual, but then problems started occurring so I opened up my case and one of the Rifeking capacitors (6.3 V, 1500 uf) had significantly leaked out its top, and another seriously bulged.
    I know that Rifeking is a brand with a bad reputation, so I will be replacing all of the Rifeking caps, even those not bulging. There are also 2 'KYS' brand capacitors on the card (16V, 470 uf) that show no signs of damage and are located on a separate area of the PCB.
    What should I replace the busted Rifekings with, and should I replace the KYS brand caps?
    Also, I once read somewhere that by using caps with more capacitance than what is required can lead to increased stability. Is this true?
  • linuxguru
    • Apr 2005
    • 1564
    Re: SciLabs GeForce 4 MX 440 with bad caps
    Any of the good brands listed in the good capacitors thread can be used. You can probably leave the 470/16 caps alone unless they're in the VRM input section (near the FETs/toroidal inductors).
      NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
      The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
      10-02-2024, 08:52 AM
      NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
      The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
      10-02-2024, 07:51 AM
      NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
      The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
      10-01-2024, 01:54 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
      EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
      by momaka
      I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
      So, here is the...
      06-06-2020, 04:39 PM
