we have here several videocards from the ELSA Gladiac MX series and they make a dark picture and in a graphic mode a dark point will result in a whole dark line. Ther are two SMT caps on it but recapping doesn't work. Probably it is a RAMDAC problem. Any other suggestions?
any possibility to repair a ELSA GLADIAC MX?
Re: any possibility to repair a ELSA GLADIAC MX?
Can you post a picture of what it is doing? Are you sure it's not the monitor or vga cable?
I have a similar problem with some older Geforce cards having dark pictures during video playback, but were fine on the GUI. Still haven't figured that problem out. Everything from Geforce 3 and up seems to do it to some degree. I can correct it a bit with the overlay controls, but it never looks right. Overdrives the brighter areas as well.
by matixkwidzynHi. Fast question. I want upgrade motherboard of my nitro 5 An515-57 GH51G LA-L181P to MB from Triton 300 PT315-53 with I7-11800H RTX3070 8G. Can somebody answer that this will be match and fully working?...
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
by ravi_1617Hi .As Power given board starts by itself ,and consumes 0.21 and than 0.33 Amps .Turns off and on again process repeats.
It seams some problem at charging section ,during this process when I blow some hot air at charging section board boot up fine.
already replaced MAX8731AETI. and few surrounding components but no improvement . does any one has same board charging section please image me. seems some components missing i have followed table 2 also
Thanks -
by ThemiI have this laptop a dell XPS 13 9310
Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure
I believe this is the spec from using micron tool to decode marking
Images of the ram
I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
Another...11-24-2024, 09:06 AM -
by KemerHello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
What worries me right now is the possibility that... - Loading...
