Taiwan Commate Computer P2BXA
  • Rainbow
    • Aug 2005
    • 1375
    Bad STONE caps, also shorted one of the MOSFETs.
    The super I/O chip is probably bad as it pulled down the power-button signal, preventing it from working. After desoldering pin #73, it can be powered on. CPU now starts but the board reboots over and over probably during super I/O initialization. I don't have replacement super I/O chip now so putting the board in "need parts, fix later" pile...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Taiwan Commate Computer P2BXA
    For me, that board would be going into the "not worth the effort, trash" pile...
    Ludicrous gibs!
    • Newbie2
      • Sep 2005
      • 885
      It's a slot 1 Pentium II, that slow in today's standards.
      Not worth saving.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Destroyer-Br
        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
        by Destroyer-Br
        I'm working on an Acer Nitro 5 unit with the following specs:
        • Motherboard: LA-J871P Rev: 1B
        • Model: Acer AN515-55-59MT
        • S/N: NHQ7JAL00403906A973400
        • SNID: 03902728734
        Initial Issue
        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
        04-17-2025, 08:18 PM
      • ongobongo
        Asus ROG Ally - Super IO Chip replacement
        by ongobongo
        anyone here who has experience with replacing the super IO chip of an ROG ally?
        I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
        Ongo
        11-17-2024, 11:27 AM
      • Loki_Fido
        Clean ME for VAIO please. Super I/O just got replaced
        by Loki_Fido
        Hi ya folks,
        Hope everyone's having a nice day.
        I recently replaced the super I/O chip and now I believe i need a clean ME for the system to come online. Cause i started the laptop and it did not start.
        Laptop details
        Sony VAIO
        Product name VJS111
        Model Number VJS111D12N
        Serial Number 7014633
        Motherboard markings
        FEILONG MB REV 1.03B
        UMT-KS 2V 94V-0 E49068 A7 1545 07-01
        Original bios file attached
        SUPER I/O chip model ITE IT8528VG
        Thanks a million in advance folks...
        05-11-2025, 11:40 PM
      • Paul20
        Swap Super I/O Lenovo Ideapad
        by Paul20
        Hi, I would like some advice.
        I have two motherboards, one with a dedicated GPU and the super I/O with obvious burn marks on it, and another working motherboard without a dedicated GPU.
        My question is: can I swap the super I/O from the motharboard without dedicated GPU to the one with dedicated GPU? Will it work anyway or is that super I/O taken from the motherboard without GPU only good on motherboards without dedicated GPU?
        The motherboards are exactly identical even in terms of versions...the only difference concerns the dedicated GPU in one and not in the other.​
        11-27-2023, 10:47 AM
