dell ltd 610 manufacture mode level 67
  • bazzbarro
    • Dec 2012
    • 25
    • kenya
    Hi good people help here pl z i have dell latitude d610 laptop when i power it on the message '' manufacture mode : level 67'' press fn -x to return to normal mode appears on screen
    when i press fn it takes a while an then brings another message the computer is docked should undo-ck and plug in the power cord and have connected power
    have gone through many forums they are suggesting flashing which is impossible for me because i cant access even bios setup or windows boot menu so am back home to bad-caps kindly help
  • bushie
    • Dec 2013
    • 57
    Re: dell ltd 610 manufacture mode level 67
    hello.i have the same problem with the same model.pls tell me if you figured it out. thanks.
    • evasive
      • Apr 2009
      • 10
      From a different forum:
      "wait until the machine asked me to hit F1 to continue (which takes awhile since it first asks to press Fn-X), at this point, instead, I hit CTRL+ALT+DEL and surprisingly, the machine booted fine. I then DIDN“T go to SETUP, but I allowed Windows XP to boot and then I reflashed the BIOS.
      Problem solved, like magic!!!
      PS: The first time I tried to go to the BIOS SETUP, but the machine frozen, then, the second time I left Windows to boot straight using the same CTRL+ALT+DEL approach, so, my advice is: do not push your luck if you manage to boot like I describe above by trying to launch the BIOS SETUP utility, let Windows boot instead and re-flash your BIOS."
      failure is not an option. it is a chance to success.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • mpower1226
        Dell optiplex 7090 boot problem
        by mpower1226
        Hi masters, need your help in solving this mystery.
        i have a dell optiplex 7090 micro that i bought from local kijiji.
        when i turn it on, error comes out saying no hard disk.
        i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
        i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
        it seems as if the computer doesnt recognize the ssd...
        01-22-2024, 10:37 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • mamado mosa
        Slow boot dell latitude 5410 laptop issues
        by mamado mosa
        So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
        The problem is it takes more than a minute to boot ..
        The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
        Can someone suggest something to fix
        06-19-2025, 06:55 AM
      • estabilito
        Swapped CPU from Fujitsu to Dell - boot guard?
        by estabilito
        Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
        05-27-2025, 05:26 PM
