Soltek 75KAV
  • shagg
    • Sep 2006
    • 8
    Soltek 75KAV
    Recently I was measuring up for a new HSF and I noticed that every single green and gold 10 v 2200 microF cap was leaking. All bulged with a crust of brown solid on the top. Soltek used decent ( think they were panasonic) caps for about half the board and some rubbish in green body with a gold negative stripe for the rest, (thanks to the acountancy team no doubt). Replaced all the green caps to be safe, cost about 8 quid from farnell for 10 x 2200mF x 10v (panasonic FM series), 8 1000mF 6.3 v and 1 x 1500 mF 6.3 volt (all FM panasonic or decent Rubys).
    First time cap replacement job and first few removals and clean ups were hard work. Soldering very easy. I used a sewing needle in pliers and 50W iron to clear holes as no solder sucker!
    No problems on booting. If you can solder, have a hot enough iron and can get decent caps then there is no reason why you can't save the life of your board by excising its poor quality caps.
    Theres not much to lose so give it a go if you have some time to kill and some patience to spare!
  • MD Willington
    • Sep 2004
    • 702
    Re: Soltek 75KAV
    Good show!
    Too bad you didn't find out earlier, before the writing was on the wall for Soltek, they used to give out Panasonic FJ capacitors for free, I received a couple batches of them.
    Soltek boards were known to have this problem for quite some time.
    Always a happy ending when it works out in the end!
    Cheers
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • tazwegion
      • Jun 2006
      • 444
      Re: Soltek 75KAV
      Other than those wretched caps' I kinda' liked the SL-75KAV... especially that REDstorm OC bios!
      Viva LA Retro!
      • shagg
        • Sep 2006
        • 8
        Re: Soltek 75KAV
        Whoops! I had underestimated the pennypinching of Soltek in my earlier post. All the sub 1000 microF caps on the 75KAV were NOT panasonics, but the dread GSC! None seem bulged as yet, so I think they will have to stay for now.
        The redstorm OC system is good, but it seems strange to produce a board aimed at overclockers and then stuff it full of bad quality caps....
        • tazwegion
          • Jun 2006
          • 444
          Re: Soltek 75KAV
          Perhaps the aim was for the short term return primarily?
          Sadly, I had to let mine go (to a new home) after it was repaired, I needed the cash for my Neo2 Platinum upgrade... I'd happily own/repair another one
          Viva LA Retro!
          • jimjoe123
            LCD TV Green/Pink screen problem
            by jimjoe123
            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
            Then each time...
            02-23-2020, 01:29 AM
          • fixxy88
            Panasonic 55DX600u repair help - no display fast green then slow red led flash
            by fixxy88
            Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
            Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
            02-22-2023, 09:14 PM
          • ItepK
            Panasonic TX-P42G30E green light blinking, no video, no audio
            by ItepK
            Hey everyone!
            I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
            This post describes my entire troubleshooting process of this TV.
            When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
            I've taken the unit apart, and I've started to check some voltages:
            • On the P11 connector, there is 15V DC only for a brief moment, then it goes
            12-22-2023, 05:06 AM
            HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
            This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-12-2024, 02:00 PM
            Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook Vero Specification for Upgrade or Repair
            This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...
            09-07-2024, 03:10 AM
