another corperate cheapskate uses bad caps
  • e_q
    • Jun 2004
    panasonic video mixers with the model wjave7 all suffer from bad caps
    the first i saw of the problem was one of the video channels went green, then the second one also went green
    bloody cheapskates over a grands worth of kit and they used substandard caps.
    angry
    about to also recap my soya p4 motherboard from 1500uf to 2200uf, any suggestions before i f*ck it up completely
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I'm surprised Panasonic used cheapo caps! What brands did they use? Panasonic makes high-end replacement caps, which I frequently use... I'd be curious to know what off-brands they used.
    Recapping your Soyo with 2200uF instead of 1500uF caps will probably not harm anything or cause any problems. Just make sure that you do not decrease the voltage rating.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Dissapointing indeed, what i would call pro equipment with bad caps. Please can we see some pics. Is the equipment still under warranty? What is the response of Panasonic to your problem?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        isnt the first time panasonic tried to cheap out and it bit em in the ass.
        i remember the panasync 1381 they installed relabled samsung crt's in
        about 9 months and they were unreadable.
        samsung tubes have always been crap.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I got another Dell P1110 monitor that was doing strange things, and I read a monitor repair forum for tips on troubleshooting this monitor (ended up being a leaky disc cap in the horiz circuit)... MANY in that forum also backed up your statement that Samsung CRT's are total crap... That's good to know! I've been out of the TV-VCR-monitor repair business for so long, I'm not up on things like that at all anymore.
          The strange thing is, Samsung RAM is one of the best around... You think that a company such as Samsung could get such an antique technology as a CRT right....... I've got a 1958 Philco Predicta in working order, and that CRT is 46 years old, and works like new.
          Team : 49813
          Join in!!
          Team Stats
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            cool
            another vintage tv collector.
            i collect/restore here too.
            working on a rca ct100 and a panasonic tr-001
            i got lucky and the crt in the ct100 is under vacuum and tests good on the 467.
            just try to find a 15gp22 today!
            your predicta must be a 17"
            the 21" tubes were almost always bad.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
