asrock, capswap+conroe
  • niexa77
    • Aug 2006
    • 8
    can i get any opinions on:
    http://www.monarchcomputer.com/Merch...y_Code=imb_775
    then do a cap swap mod on it (i presume for 89usd you will be getting cheaper caps?
    this will work out (even with expensive caps) to be cheaper than one of the 250-350usd M/B's people jumping on the conroe bandwagon are flaunting... plus it would be a chance to whet my cap-swapping beak
  • Rainbow
    • Aug 2005
    • 1375
    Re: asrock, capswap+conroe
    So far I've seen only good caps on ASRock boards. The caps are good but boards are not.
    • niexa77
      • Aug 2006
      • 8
      how do you mean the boarsd are not? layout?
      • gonzo0815
        • Feb 2006
        • 1600
        The conroe xfire hase realy bad caps. All the small caps (1000uF) are Evercon, VRM input is TK series, probably from TEapo? there is no brand marking on them. VRM output are ost RLS. I was personally very disapointed, that they even used some inferior brand on the vrm. But considering the expensive supply units for memory, chipset and PCI-E (all are switchers, not those usuall Asrock like linear converters) i assume there are no money left, to fit the budget. And as most younger developer do not know anything abouth badcaps, i suppose they have easily choosen those crap caps.
        I duno how long those caps can sirvive, but if you consider overclocking, i would replace all of those crap. And personally, i would replace them in any case, as i can do it easily. Any way, there are alot caps on it. Thus i would take some time to do it.
        • Big Pope
          Approved Vendor
          • Dec 2005
          • 426
          Yes, layout and some littles electronics parts are not.
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
          • gonzo0815
            • Feb 2006
            • 1600
            Well, this is true for all K7 & K8 boards, but those Intel boards especially the conro xfire &co. have reversed the situation. IMHO all ímportant sections are comparable with other high quality boardmakers from elektronic desing & components, but now the caps are realy worse. It seems that they have made a better desing now, but have problems to fit the budget with high grade capazitors. For m,e and others, who are able to replace the caps, this is very interesting. At least i know, what i would do when switching to cor2duo....
            • Rainbow
              • Aug 2005
              • 1375
              VRM design was really bad on many ASRock boards - with ideas as stupid as powering P4 Prescott CPU from 5V line. And those buggy BIOSes...
              Maybe the design is better now but BIOSes most probably not. And they use bad caps now...
              • gonzo0815
                • Feb 2006
                • 1600
                Well. true, Asrock is in no way high end stuff. I think we can agree to this. And yes, there are some very ugly desings from them, but wich boardmaker has not some ugly badboy in his history? I personally examine any board closely, before i get it, regardless of brand. And if i don`t find something to bad for me, i usually know exactly what i get and what not. So regarding this coroe xfire, i would say it is from a techical point of view very good or at least comparable with the more expensive brands, except with the choice of crap caps. Sadly i haven`t seen the bios, as my neighbor has dammaged his LGA socket, before i have accesed it.
                • gabrieljma1
                  Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                  by gabrieljma1
                  I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                  The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                  I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                  10-08-2025, 03:32 PM
                • Exim
                  ASRock N100M, no picture no boot, but semi-alive
                  by Exim
                  Hi guys,
                  I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                  ASRock N100M special features:
                  - CPU soldered to board, small Intel 12th gen
                  - iGPU
                  - four POST LEDs
                  Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                  I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                  Symptoms:
                  - no picture/signal on any of the display connectors,...
                  04-01-2025, 02:36 PM
                • MasterCap
                  What IC does AsRock usually use to make the PWM signals for GPU fans ?
                  by MasterCap
                  I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                  Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                  But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                  12-28-2024, 08:42 AM
                • nolaryie
                  BIOS .bin file for ASRock B450M Steel Legend
                  by nolaryie
                  Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                  I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                  Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                  If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                  Thank you!
                  08-06-2025, 12:01 PM
                • khanhtq0
                  Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
                  by khanhtq0
                  I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
                  I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
                  I suspect the original Intel ME and descriptor...
                  08-06-2025, 02:14 AM
