MSI 694D ok to use 16v caps?
  • mac_cad
    • Aug 2006
    Hi, i'm from Portugal and recently a friend gave me a server system that was not being used.
    It has a msi 694D pro v1 mobo, 2x p3 733, 1 gb ram, scsi card and 18gb hd.
    It was working fine until it started to reset itself, I thought it was the psu, but then searched in the net for this mobo, and found your forum.
    After reading your posts I confirmed that the 2700 caps are bulging and inflated.
    My doubt is if I can use the following caps for replacement:
    2700 6.3v -> 3300 16v
    1000 6.3v -> 1000 10v
    That's what I can find around here.
    Thank you for your support
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI 694D ok to use 16v caps?
    as long as they are high quality low esr and will fit.
    a 3300@16 panasonic fm is 12.5mm od
    your originals are 10mm
    • mac_cad
      • Aug 2006
      Thank you for replying so soon.
      what about 2200 10v instead of the 3300 16v?
      is it possible to replace electrolit capacitors for solid capacitors?
      I'm an architect, I really don't know much of electronic values, but I like to learn by searching e experiment by myself.
      • Spacedye69
        • Nov 2005
        • 698
        • US
        I liked experimenting with myself, but my wife told me I had to quit when we got married.
        • mac_cad
          • Aug 2006
          thanks... that was a very good explanation.
          I really learned with your post.
          Now I know who is the kid around here...
          By the way, do you Know how to write a full sentence in portuguese?
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Are you offended? My apologies. You will learn that Badcaps has many children, I'm just the prettiest!
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              I've used 2200uF caps in place of the 2700uF caps many times, it has never caused any issues.
              The biggest thing to remember on the 694D is the C390 mod.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • mac_cad
                • Aug 2006
                Hi, I've replaced the 2700 uf 6.3v with 2200 uf 16v.
                The system is stable, both cpus work fine - no more resets.
                The C390 cap looks fine and is normally fitted - minus with minus.
                If I replace it should I invert the polarity? It really seems to be ok.
                Thank you for your help!
                  by momaka
                  03-12-2025, 03:42 PM
                  HP Pro Pro 3300 SFF Pro 3300 G850 Specification for Upgrade or Repair
                  This specification for the HP Pro Pro 3300 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Pro 3300 SFF boardview and Pro Pro 3300 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-12-2024, 03:44 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
