Interesting Abit Kt7-RAID recapping issue.. :-)
  • gg1978
    • Dec 2004
    • 431
    Hey all,
    I was going through my stack of old boards, and i found an Abit Kt7-RAID.. Just for "old times sake" i decided to do a custom recap job on it..
    The caps on the CPU VRM secondary side were replaced with Panasonic FJ's from a scrapped MSI Neo 4 platinum, with a 330uF Sanyo Oscon added for noise cleanup. The CPU VRM primary caps, chipset/RAM VRM secondary side were all replaced with Nichicon PW, appropriately sized with larger diameter caps for longer life.. 7K hours plus...
    Now for the interesting part, the chipset/RAM primary side. Originally it had a set of 4 16V 1000uF Jackons in it.. I had replaced the set of 4 with a single 3300uF 6.3V Nichicon PW, and a 330uF 6.3V Sanyo Oscon. I had no idea that the 16V voltage rating was actually needed. ;-) Turns out the KT7 actually uses +12V from the ATX connector to power the RAM and chipset.. I had intended to check the noise at the VRM input, and i kept seeing +12VDC there.. I had assumed that like pretty much all other older Socket A boards that the VRM would be fed off +5V.
    So that 3300uF Nichicon PW and 330uF Oscon got the benefit ;-P of having +12V applied to a pair of 6.3V rated caps, and neither one vented or showed any sign of distress after over 24 hours of Prime95 burnin.. The board was perfectly stable either stock or overclocked, though i forget what type of FSB the old KT133 chipset would top out at..
    Of course i'm going to be unsoldering them and replace them with 16V rated parts, but the fact that they seem to have survived having double their rated voltage applied for >24 hours is encouraging..
    So the lesson today is that if you see 16V or higher rated caps on a board, it's probably a good idea to check the voltages actually present there. Don't just assume that because the board lacks the ATX 12V connector that none of the onboard VRMs might have +12V at its input..
    This should also serve as a warning to those that still may have Abit KT7-X boards that having the RAM/chipset VRM short would result in +12V being applied to your RAM and chipset.. I think you would see more than just burnt labels on your RAM in that case.. :-P
  • Hagis2k
    • Jul 2006
    • 66
    Re: Interesting Abit Kt7-RAID recapping issue.. :-)
    Hehe like playing with fire i see
    • Perry Babin
      Operating caps well below rated voltage
      by Perry Babin
      I think this has been answered but I couldn't find the thread.
      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
      Or would it require reforming?
      05-23-2024, 05:43 PM
    • Phil289
      Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
      by Phil289
      Hi
      Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
      Is there any reasons why they shouldn't be used?
      I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
      If I can't find any Panasonic what would be any other good makes to consider?
      Thanks 🙂
      09-25-2022, 03:02 PM
    • Foetuss
      Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
      by Foetuss
      Hi all
      Hope this is in the correct place.
      I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
      Could use some double checking to see if I'm not doing something stupid .
      Pictures of the boards are attached.
      What I will be replacing with what : (planned)
      Soltek Golden ::
      4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
      6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
      01-18-2025, 11:44 AM
    • ziplock
      Abit BE6-II motherboard
      by ziplock
      Greetings,
      I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
      I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
      04-20-2025, 02:09 PM
      ABit IP35 Pro Motherboard Schematic
      ABit IP35 ProABit IP35 Pro Motherboard Schematic
      A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
      10-31-2024, 02:06 PM
