Bad Emachines T6216 Motherboard
  • Bahdumtshw
    • Mar 2012
    • us
    Just writing in because I'm not sure what else I can do at this point.
    When I press the power button, the only thing that comes on is the fan and the board will not POST.
    Here are the things I've tried thus far:
    1. Replacing bad capacitors. There was a line of 4 visibly bulging ones close to the processor.
    2. Swapping out PSU. I tried two seperate power supplies which were the OEM one and one from a dell dimension 2400.
    3. Cleared CMOS. I attempted to clear it by using both the battery removal and jumper pin technique.
    4. Removed all components except for processor and RAM and tried to power on. Also, removed everything including RAM and tried to power on.
    That's about all I've done thus far. Now, this was my first recapping, so I'm a little worried I messed something up. To note, I saw that removing the bad capacitors was simple, yet I had to really work to clear the holes using a needle as it would go in easy, yet get stuck when I pulled the iron away.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Bad Emachines T6216 Motherboard
    Nvidia chipset, 'nuff said
    oh not 'nuff if you don't know. the chip probably needs to be reflowed/reballed
    https://www.google.com/search?hl=en&...4l3l3l0.frgbld.
      ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
      This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-12-2024, 03:36 PM
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
